Inventor Forum
How to export an Assembly to a STEP file
4 REPLIES 4
mustafaSNRRQ
14803 Views, 4 Replies
I have an assembly and i'm trying to export it as a STEP file. When i click Save As --> Save as Type, it doesn't give me the option to pick STEP file. Attached file below.
Thank you
4 REPLIES 4
blandb
in reply to: mustafaSNRRQ
File > Export > CAD Format.
Hope that helps.
Autodesk Certified Professional
Cadmanto
As @blandb mentioned, you will not find it under the save as command.  You have to select the export.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
mcgyvr
"Save Copy As" also works just fine..
johnsonshiue
in reply to: mcgyvr
Hi! On top of what has already been mentioned by our experts, you can also set up an STEP Export task in Task Scheduler. It will export a selected file or files in selected project folders to STEP in a batch.
Many thanks!
Software Test Engineer
Technology Administrators
