I have an assembly and i'm trying to export it as a STEP file. When i click Save As --> Save as Type, it doesn't give me the option to pick STEP file. Attached file below.
Thank you
Solved by johnsonshiue. Go to Solution.
Solved by Cadmanto. Go to Solution.
Solved by blandb. Go to Solution.
File > Export > CAD Format.
Hope that helps.
"Save Copy As" also works just fine..
Hi! On top of what has already been mentioned by our experts, you can also set up an STEP Export task in Task Scheduler. It will export a selected file or files in selected project folders to STEP in a batch.
Many thanks!
