How to export an Assembly to a STEP file
mustafaSNRRQ
mustafaSNRRQ
I have an assembly and i'm trying to export it as a STEP file. When i click Save As --> Save as Type, it doesn't give me the option to pick STEP file. Attached file below.
Thank you
Accepted solutions (3)
blandb
File > Export > CAD Format.
Hope that helps.
Autodesk Certified Professional
Cadmanto
As @blandb mentioned, you will not find it under the save as command.  You have to select the export.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
mcgyvr
"Save Copy As" also works just fine..
johnsonshiue
Hi! On top of what has already been mentioned by our experts, you can also set up an STEP Export task in Task Scheduler. It will export a selected file or files in selected project folders to STEP in a batch.
Many thanks!
Software Test Engineer
