Inventor Forum
How to bend this model in sheet metal
6 REPLIES 6
617 Views, 6 Replies
Hello!
I hope you guys can help me with this part i'm trying to create in inventor.
I tried everything but i can't get it done.
Can anyone explain me how to bend this part in a sheet metal?
Thanks.
Greets Nico
6 REPLIES 6
jhackney1972
The part will be very hard to model directly in Inventor because it is a deformation part.  The 90 degree bent part is not an issue but since one leg is bend along its edges, it forms a deformation at the intersection of the bend.  Inventor does not have any functions that will handle this space.  It can only be estimated with a lot of experimentation.
That is my opinion.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
dgreatice
unfortunately, it not all are bend Plate
1. L bend it OK
2. it must be punch process
3. Blank Size must be rectagular Plate 125mmxWidth, after L Bend, then Puch. i cant be flatten again in Inventor sheet metal. if can flatten blank size may not rectangular again.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
in reply to: dgreatice
If you punch in a sheet metal, it goes all the way through, right?
I don't understand how I can punch this model.
dgreatice
punch process i mean is punch with tool like dies. this my example abount punch tool from my work, it punch at the edge of plate, the result can same with you picture.
kelly.young
@Anonymous that can be made with Inventor but using the sheet metal bend tools for that will not provide a flat pattern.
Quick example using extrude and loft.
The reason for this is that in the real world you would be making two mating dies and sandwiching the metal between.
You could hang the piece off the side of the machine and bend, but that isn't really best practice in my opinion.
How are you planning on making this in real life?
Please select the Accept as Solution button if a post solves your issue or answers your question.
Yes thank you!
I punched it using an iFeature.
It costed some time but I have it :D.
Thanks guys for helping me.
Technology Administrators
