@Anonymous Your first image seems fine to me, it's a different printer so the options you get are different. this is normal and doesn't have anything to do with your actual issue.
The 2nd image though, is this in a part/assembly?
The black background is confusing me a bit as well, could be the dark theme or maybe, just maybe, you have opened an AutoCAD dwg directly?
The radial menu i see seems to suggest that you've right-clicked on the viewcube and the menu shown is what you get when in a part/assembly.
If it is a part/assembly, then try starting a new .idw (or .dwg if that's what you use) and create a base view and some projected views of this part file.
If it's a .dwg you are opening, then i'm not sure how to achieve what you want.
If it's 2D data then you'll have to redraw it in Inventor, if it's 3D then there might be other options but i don't usually deal with AutoCAD files so i'm unsure.
If you can share the file here, that might help to understand the issue better as well.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
