Inventor Forum
Highlighted selection not shown transparent
10 REPLIES 10
Message 1 of 11
markus.moi
589 Views, 10 Replies
markus.moi
How can i get the selection to be shown transparent (seen through other parts)? I managed to do this previously as seen from the picture, but i cant seem to replicate it now.
Thanks in advance for any responses
Labels (3)
10 REPLIES 10
Message 2 of 11
-niels-
in reply to: markus.moi
-niels-
Maybe "enhanced highlighting" is not enabled?
Application options > Colors tab.
Awesome assembly btw.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Niels van der Veer
The Netherlands
Message 3 of 11
markus.moi
in reply to: -niels-
markus.moi
Hi Niels,
Enhanced highlighting is enabled.
Hi Niels,
Message 4 of 11
CCarreiras
CCarreiras
hi
I believe the behavior has changed in the last versions.
You can ask to change this in the "Inventor Ideas forum". If the idea gets enough votes, they probably change it back.
CCarreiras
hi
CCarreiras
Message 5 of 11
-niels-
in reply to: CCarreiras
-niels-
@CCarreiras are you sure? It seems to be working for me (IV2023.2):
Niels van der Veer
The Netherlands
Niels van der Veer
The Netherlands
Message 6 of 11
CCarreiras
CCarreiras
@-niels- ,I have also 2023.2.
Also changed some options in application tools, but the result was always the one you can see below.
I Have Nvidia Quadro, Autodesk Certified.
but.... @-niels-  have a different result, what can be causing the difference??
CCarreiras
CCarreiras
Message 7 of 11
markus.moi
markus.moi
I mean theres only one option, so its not so much to get wrong... what build are you using - @CCarreiras?
I get this with these settings:
Message 8 of 11
markus.moi
markus.moi
@CCarreiras and @-niels- I figured it out! It was an easier fix than i anticipated.
Its all about the "scheme", it has to be the "presentation" scheme:
Thanks anyways!
Thanks anyways!
Message 9 of 11
-niels-
-niels-
Intriguing... i use the "forest" theme...
I didn't check them all, but i can confirm that it doesn't work for me either when i use the "light" theme.
@johnsonshiue is this a known thing?
Niels van der Veer
The Netherlands
Niels van der Veer
The Netherlands
Message 10 of 11
CCarreiras
CCarreiras
HI!
For me works in almost every scheme (tried in a couple, not all), except the default (Winter night).... 🤣
This version 23 is all messed up... 😖
...Anyway, it would be nice to have both options in all layouts schemes!!!
CCarreiras
HI!
CCarreiras
Message 11 of 11
johnsonshiue
johnsonshiue
Hi Niels,
Indeed, there seem to be significant difference between Light theme and Dark theme in terms of selection highlight. I am sorry I don't have a good explanation. The combination of effects is very hard to understand. I guess there are choices for users to try and find the suitable one.
Many thanks!
Software Test Engineer
Hi Niels,
Many thanks!
