I am trying to turn off panel titles but it seems not working.
It doesn't make any difference when restarting Inventor.
Your helps are much appreciated.
Solved by johnsonshiue. Go to Solution.
Hi
Check if you have installed all updates
Kacper Suchomski
I think I have.
It works for me on 2023.5 (latest update level). I'm running Windows 11 23H2, AMD Radeon 4GB graphics, 16GB RAM, pretty low-end computer. I wonder what's different on your end?
Sam B
Inventor Pro 2025.1 | Windows 11 Home 23H2
Sorry for the late response.
I have the similar machine but with 32Gb Ram.
Hi! I cannot reproduce the behavior on 2023.5 either. Maybe you want to use Inventor Reset Utility to reset all settings back to install default.
Many thanks!
Thanks @johnsonshiue .
It works after reset. 👍
I was suspecting that it'd be a hardware issue (e.g. graphic card).
It comes back today...
Have to do reset again.
I think it is a bug?
Hi! This might mean that there is a system process wiping out user settings in your environment. I don't believe such process is initiated or managed by Inventor. A few things to try. Right-click on Inventor desktop icon -> Properties -> Compatibility -> check "Run as Admin."
Or contact your IT department to see if there is a way to preserve your settings in %ProgramData%.
Many thanks!
