Inventor Forum
Hide Panel Titles in Release 2023.5
8 REPLIES 8
Message 1 of 9
BeKirra
319 Views, 8 Replies
BeKirra
I am trying to turn off panel titles but it seems not working.
It doesn't make any difference when restarting Inventor.
Your helps are much appreciated.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
X² + Y² = C²
8 REPLIES 8
Message 2 of 9
kacper.suchomski
in reply to: BeKirra
kacper.suchomski
Hi
Check if you have installed all updates
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Hi
Kacper Suchomski
Message 3 of 9
BeKirra
in reply to: kacper.suchomski
BeKirra
I think I have.
X² + Y² = C²
I think I have.
X² + Y² = C²
Message 4 of 9
SBix26
SBix26
It works for me on 2023.5 (latest update level).  I'm running Windows 11 23H2, AMD Radeon 4GB graphics, 16GB RAM, pretty low-end computer.  I wonder what's different on your end?
Sam B
Inventor Pro 2025.1 | Windows 11 Home 23H2
Sam B
Message 5 of 9
BeKirra
in reply to: SBix26
BeKirra
Sorry for the late response.
I have the similar machine but with 32Gb Ram.
X² + Y² = C²
X² + Y² = C²
Message 6 of 9
johnsonshiue
johnsonshiue
Hi! I cannot reproduce the behavior on 2023.5 either. Maybe you want to use Inventor Reset Utility to reset all settings back to install default.
Many thanks!
Software Test Engineer
Many thanks!
Message 7 of 9
BeKirra
in reply to: johnsonshiue
BeKirra
Thanks @johnsonshiue .
It works after reset. 👍
I was suspecting that it'd be a hardware issue (e.g. graphic card).
X² + Y² = C²
X² + Y² = C²
Message 8 of 9
BeKirra
BeKirra
It comes back today...
Have to do reset again.
I think it is a bug?
X² + Y² = C²
X² + Y² = C²
Message 9 of 9
johnsonshiue
johnsonshiue
Hi! This might mean that there is a system process wiping out user settings in your environment. I don't believe such process is initiated or managed by Inventor. A few things to try. Right-click on Inventor desktop icon -> Properties -> Compatibility -> check "Run as Admin."
Or contact your IT department to see if there is a way to preserve your settings in %ProgramData%.
Many thanks!
Many thanks!
