Hi everyone,
Hopefully you guys can answer my novice question and explain what's happening in the dynamic simulation environment.
As I am inserting the last joint on a 4-bar linkage, the assembly re-orientates by X degrees through the final degree of freedom. This is frustrating because I entered the DS environment with the assembly model positioned at one extremity of movement, and now I have lost the starting position. I can't quite work out why the software has picked this number of X degrees.
At a wild guess I might assume one of the earlier joint co-ordinate systems is defining a global position of everything else.
To explain my models: This 4-bar link looks like a simple diamond, two long side, two shorter sides. The base link is grounded, the next two links can each rotate using revolution joints, the 4th link can then translate and is connected to the ends of the 2nd and 3rd links. Mechanism status shows 1 DoF. There's also a pair of compression spring style mounts, attached to opposing corners of the diamond shape. In total there are 4 revolution joints, 2 point-line joints and 1 prismatic joints. Essentially I want to control the position of the 4-bar link w.r.t. a perpendicular distance from a flat surface on another grounded part.
If you would like the model uploaded, I’ll have to create a non-IP version, but that shouldn’t take to long.
I know that I can edit a joint’s properties and update the initial conditions to choose a starting position I want. But I would like to understand the reason why it moves by X degrees.
FYI - I have been teaching myself DS for the last few weeks and have been using Wasim Younis’s book (massive thumbs up and kudos to Wasim) and completing the different tutorials. So my general understanding of DS is much improved, but as to the reason why the mechanism moves by X degrees has left me totally scratching my head.
For reference I am using Autodesk Inventor 2019, build 330, release 2019.4.
Looking forward to some insight!
Build: 330, Release: 2019.4
Windows 10 Pro, Intel i5-6300HQ, 16GB RAM
NVIDIA Quadro M1000M
