Help with Lofts
Help with Lofts
david_teasdaleNCZQF
Observer Observer
Help with Lofts
david_teasdaleNCZQF
Observer
Observer
I have a basic understanding of how to do lofts, but I now need to do something a bit more complex, and it isn't just 'working' how I want first time.
I want to model in a conveyor belt that is transitioning from the troughed profile you see on the left to the overlapping cylindrical profile on the left.
Is anyone able to help with getting this to work?
CCarreiras
Hi!
Can you share your file here?
CCarreiras
Alexander_Chernikov
It would be preferable to see what result you wanted to get and, if possible, attach the original file.
If I understood the problem correctly, you want something like this?
Then
1. I recommend adding a small gap at the top of the spiral;
2. It is necessary to manually add the desired correspondence of points on the sections.
I attach the working file.
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
david_teasdaleNCZQF
Observer
Observer
Here it is
david_teasdaleNCZQF
Observer
Observer
Hi, yes you have it right there, that's spot on what I'm after. Thanks very much, I'll have a tinker about with it and see if I can replicate the result just for my own understanding 👍
CCarreiras
I suggest you create these kind of more complex lofts in surface mode to avoid tool failings.
Also the sketches will be easier.
After you get the surface, you just have to apply Thicken tool to add solid to the surface.
File attached (V26)
CCarreiras
