Thread, file xls
Thread, file xls
eduardoaw2
Thread, file xls
eduardoaw2
Hello, After install the inventor 2026 professional the software could no find the file thread.xls, but the file is in the same place alwais, of the others versions...Someone have this problem too?
karthur1
Are you using the same project file as before?
eduardoaw2
Yessss
Paul-Mason
I think it now needs to be converted to the newer .XLSX format
Inventor 2026 Pro
HP Z4 G4 workstation
Xeon
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
karthur1
Post a screen capture of the error and also of you IPJ.  Expand the Folder Options so we can see the nodes under it.
karthur1
2024 still uses the .XLS format.  Not sure about 2025, but 2026 uses .XLSX format
eduardoaw2
Yesss!
This worked
Thank you!!
