Inventor Forum
Generate suface between 2 space lines (3D sketch)
13 REPLIES 13
Message 1 of 14
guillermo.casasfojo
465 Views, 13 Replies
Hi all,
I wanna generate a surface between 2 space lines that were created in a 3D sketch. I tried the Ruled Surface feature but I do not get the expected results.
13 REPLIES 13
Message 2 of 14
Attach *.ipt file here
Message 3 of 14
Hi JDMather,
thanks for your reply. I can not see the attached file.
Message 4 of 14
What happens when you attempt to Attach the file here?
Message 5 of 14
do not know. Never did it.
Message 6 of 14
maybe you can just describe to me the steps to be done.
Tks
Message 7 of 14
Tks
Step 1.  Click Reply
Step 2. At bottom of Reply to Message. In the Attachments box,  Drag and Drop or Browse to the file location to Attach.
Step 3. Click Post.
(You must use the web forum to accomplish these 3 Steps, not email reply.)
Message 8 of 14
Here it is
Message 9 of 14
That is an assembly file, not a part file.
Parts are created in *.ipt files.
Message 10 of 14
Sorry, try this one
Message 11 of 14
I did not see any Yellow lines as shown in your original problem description - so I had to guess...
See Attached file...
Message 12 of 14
Okk. That works for me!
Thank you very much!
Message 13 of 14
iProperties indicates that you have not installed the latest Updates for 2021.
I recommend that you go to http://manage.autodesk.com and get the Updates.
Message 14 of 14
Ok understood! Updates are managed by my organization but I will et them know! Thanks again for the support!
Guillermo Casas
