Hi all,
I wanna generate a surface between 2 space lines that were created in a 3D sketch. I tried the Ruled Surface feature but I do not get the expected results.
Solved by JDMather. Go to Solution.
Attach *.ipt file here
What happens when you attempt to Attach the file here?
@guillermo.casasfojo wrote:
maybe you can just describe to me the steps to be done.
Tks
Step 1. Click Reply
Step 2. At bottom of Reply to Message. In the Attachments box, Drag and Drop or Browse to the file location to Attach.
Step 3. Click Post.
(You must use the web forum to accomplish these 3 Steps, not email reply.)
That is an assembly file, not a part file.
Parts are created in *.ipt files.
I did not see any Yellow lines as shown in your original problem description - so I had to guess...
See Attached file...
iProperties indicates that you have not installed the latest Updates for 2021.
I recommend that you go to http://manage.autodesk.com and get the Updates.
Ok understood! Updates are managed by my organization but I will et them know! Thanks again for the support!
Guillermo Casas
