Inventor Forum
GeForce GTX 1050
22 REPLIES 22
Message 1 of 23
mrattray
75327 Views, 22 Replies
GeForce GTX 1050
Management is considering buying us new graphics cards. We've been running OpenGL cards (I have a FirePro V5900 currently). I remember reading that these are no longer recommended for Inventor users, that we should be using Direct X based gaming cards now. I've been asked my opinion on a GeForce GTX 1050. I haven't kept up on graphics hardware lately, does anybody care to share their opinion/experience on this card with me? Do you have another card that you would recommend?
Thanks!
Mike (not Matt) Rattray
22 REPLIES 22
Message 2 of 23
-niels-
in reply to: mrattray
Tagging @Neil_Cross on this one.
I can't really comment other than saying that we've been using gaming cards for many years now without issues.
Currently using a GeForce GTX 670, so that's a bit older. my laptop has a geforce 900 something mobile series which also works fine.
I guess for people to give a better indication if it will suffice, you'll need to give a bit more detail on what you'll be doing with it.
If it's only for inventor, or do you use other software that might still benefit from OpenGL, that sort of stuff.
At the moment, for example, there seem to be some issues with the newest geforce cards not being fully supported in 3DS Max for GPU rendering...
Hope you can get the info you need. Smiley Wink
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 3 of 23
mdavis22569
@mrattray
I've been dealing with time ..
 I have the Asus GTX1070 Strix ..and LOVE IT!
I haven't had any issues, crashes etc with it. I've been doing AutoCAD, ACAD LT, Revit, Fusion and Inventor 2015-17 on it. Rendering, etc
Mike Davis
Message 4 of 23
Neil_Cross
The 1050 will function but it's the cheapest and most weak card on the market. Inventor doesn't scale in visual performance with graphics card power but I still wouldn't be buying the cheapest card on the market to run 3D CAD in a business. The 2GB video RAM is probably what will get you first so look at the 1050Ti or the 1060 3GB if price is a factor to consider. But honestly, I haven't tested a V5900 but looking at the specs I wouldn't expect to see much of a gain at all in going from that to a entry level gaming card in Inventor. If you're currently experiencing performance issues I would reckon the issue lies elsewhere in the system
Message 5 of 23
Ray_Feiler
Maybe this can help you decide.
http://www.videocardbenchmark.net/high_end_gpus.html
http://www.videocardbenchmark.net/gpu_value.html
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 6 of 23
Neil_Cross
Just bear in mind those are charts based on synthetic benchmarks and bears no resemblance to how Inventor will use a GPU
Message 7 of 23
mdavis22569
in reply to: Neil_Cross
I also built a system with the GTX1060 Strix too ..and that's been great so far too
Mike Davis
Message 8 of 23
Ray_Feiler
Would you recommend any of the top 10 cards listed on the high end chart for Inventor?
Message 9 of 23
dgorsman
How many do you need to get?  If its in the dozens, even a little savings on the entry-level card can add up.  If the budget can handle it, I second the recommendation of a mid-range card.  Gives you a little more capability to handle any more advanced features that may come out in the next couple of years.
The term "gaming card" should probably be dropped at this point.  Aside from negative connotations with management (and bean counters), its really not an accurate description.  They are as capable with the most commonly used features, and even some of the less commonly used ones.
Quadro/Tesla cards are making a bit of a comeback - Mental Ray rendering, and ReMake local construction, are both examples of where serious comparisons are required.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 10 of 23
Neil_Cross
in reply to: dgorsman
+1
Message 11 of 23
mrattray
Thank you to everybody for your comments, they're all very helpful.
@dgorsman I think we're really only looking for 2 at this time. We have more users, but the rest of them do pretty basic work and are fine with the hardware they have.
@Neil_Cross
We usually only have issues if we're trying to work with complex geometries or moderate to large assemblies.
Here's a quick example that gives me some lag and chop when I try to rotate or zoom (I would consider this moderately large for what we typically do):
Here's my system specs:
Inventor 2016.2.2 build 236
Windows 10
Dell Precision T5600
Intel Xeon: 3.3GHz x 4 Cores
32 GB RAM
The other user that we're shopping for a card for is using a comparatively lower powered system and complains a lot (and I've seen it myself) about poor performance. He's using the same version Inventor/Windows as me but on a Dell Optiplex 990 w/ 8GB ram (I'm not sure what processor he has, but I want to say it's an i5).  I suppose I'm not entirely convinced that it's a graphics issue, but I can't imagine the weak link being elsewhere in our systems.
Message 12 of 23
mrattray
Our controller (who doubles as IT) came by to talk to me about. Apparently, he has a GT 610 (1GB). Also, I learned he still has HDD's (I thought he had been upgraded to SSD's). So, we agreed to order him some more RAM, SSD's, and GTX 1050Ti. Depending on how that works out for him we'll see whether to order a second 1050Ti for me or if we need something more.
Thank you, everybody, for your help.
Message 13 of 23
Neil_Cross
Exactly which Xeon is it? The T5600 has the Intel C600 chipset which means I think you'll have the E5-2670v0 Xeon? That's really old now, so regardless of the 3.3GHz you'll probably be bottlenecked by that more than anything else as it's an old architecture.  I honestly don't think you'll see much of a performance improvement from a newer GPU but it can't help to rule it out.  But pan/zoom/orbit is CPU load not GPU, there's almost no load on the GPU at any point during the use of Inventor.
Message 14 of 23
mrattray
I would have never guessed that, but I did just verify it by watching task manager while spinning a model. Are there any activity in Inventor that does load the GPU?
Device manager confirms the C600 chip set, but lists an E5-2643.
Message 15 of 23
Neil_Cross
Ah OK, that's the one that turbos to 3.5GHz I was thinking of the one that boosts to 3.3GHz.
Don't get me wrong they're absolutely not terrible by any stretch, it's a fine system for most jobs but that CPU is now 5 years old and is likely where the bottleneck is at.  It's still a hyperthreaded 4 core Xeon running at 3.5GHz, I just don't think you're going to get any kind of meaningful gain on what you're working on by buying in a new GPU.
A good low level test to compare against others would be to run the Inventor Bench on your PC, see where you're at with that.  I would suspect your system would come in somewhere between 5-7 range.  Not sure if you've seen the thread on here, it's a canny big one, the download for the benchmark tool is here http://www.mgfx.co.za/software/tools-for-inventor/
Message 16 of 23
AutoCAD LT 2018
Good evening, I'm hoping that you might be able to help me.  I just purchased a Dell XPS 15 with a NVIDIA GTX 1050 .  I am having difficulty with the 2 additional monitors that I am using.  One monitor is hooked up through HDMI through the Dell Thunderbolt adapter.  The other monitor is hooked directly to the laptop using an HDMI cable.  I can't seem to find a setup combination that the laptop text is large enough to see (without my face being 6" away from the screen - lol) and the external monitors not flashing, being glitchy, and text looks awful and hard to read in my drawings.
Monitors are 1920x1080 and the laptop is 3840x2160.  I  have tried zooming on the laptop, lowering the resolution.  I am at a complete loss.  I am ready to box it up and ship it back at this point.
ANY HELP or suggestions you can offer me will be GREATLY appreciated.
Message 17 of 23
johnsonshiue
Hi! This is Inventor forum so I am not entirely sure if the discussion here would be relevant to AutoCAD LT 2018. Graphics behaviors can be confusing and hard to debug. Sometimes it is the graphics card related but sometimes it can be the setting related. It is hard to tell what is causing the problem without seeing it and trying it.
Just from a logical standpoint, it may be better if the two monitors are running on the same resolution. Try changing your laptop resolution to the same as the secondary monitor. Does it work better? I am not advocating you to buy a 4K monitor. You might want to do some testing in a hardware store. Bring your laptop to a local store and try hooking up with a 4K monitor and set the same resolution as your laptop. I am just curious if the problem would go away if the two monitors are on the same resolution.
Many thanks!
Software Test Engineer
Message 18 of 23
!!!! SOLUTION !!!!
I was uninstalling everything and getting it ready to be able to ship back to Dell. Knowing that it was going back and I couldn't "mess up" anything I started looking at all different kinds of settings. WOW! This laptop has 2 TWO Video cards. By default everything uses the standard Intel 9xx.
You can right click on the AutoCad LT 2018 icon and choose what video card you want to use as default. DUH! Once I chose the NVIDIA GTX 1050 everything starting appearing as it should on my two external monitors.
I changed the resolution on the laptop monitor down to closer match my monitors resolution and now the text is a size that can be read without the use of a magnifying glass.
I am still playing around with different settings so if anyone is still interested just let me know.
Sorry to post in the wrong forum.
Message 19 of 23
How is this laptop with Revit? Do you think that 3D modeling (reinforcement) would be seen in good details?
I am having problems with 3D model... It looks all very messy when I switch realistic details on.
Bojan
Message 20 of 23
Sorry - this one I can't answer. I have not tried Revit on this system. Sorry.
Technology Administrators
