Failure to add Add-Ins
vinayL7WQ5
Message 1 of 11
vinayL7WQ5
I have recently installed Thread-modeler and Vault Client in my computer but they do not show up in the Inventor. Please help me in figuring out how to,
1. Add Vault extension to the Inventor application.
2. add thread modeler Add-in.
I'm not sure if these errors are related but my App manager in Inventor fail to load in the application, and throws an error " Unexpected error when loading dialog".
Replies (10)
Message 2 of 11
johnsonshiue
Hi! What release of Inventor are you on? Have you applied the updates? I suspect this might be due to lack of certain shared components to support later Win10 builds. Please install the latest Inventor updates applicable to your release.
Many thanks!
Software Test Engineer
Message 3 of 11
vinayL7WQ5
Hello Johnson,
Following your advice,I have updated all my Autodesk applications to 2021 versions and currently, I'm able to access Vault in my Inventor. Thank you for the suggestion.
However, I'm still not able to load the Threadmodeler Add In. It does not show up in the Add-In Manager and I continue to receive the same "Unexpected error when loading Dialogue" error from the app manager.
Please advice.
Thank you
Message 4 of 11
johnsonshiue
Hi! The add-in does not officially support Inventor 2021. Please take a look at the discussion comments on the page.
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=2540506896683021779&appLang=en&os=Win64
"As others have said, to get it to work with 2021 simply navigate to this file:  open c:\ProgramData\Autodesk\ApplicationPlugins\coolOrange_threadModeler.bundle\Contents\coolOrange.ThreadModeler.Inventor.addin and edit <SupportedSoftwareVersionLessThan> (you can use notepad) and change the line <SupportedSoftwareVersionGreaterThan>21..</SupportedSoftwareVersionGreaterThan>
  <SupportedSoftwareVersionLessThan>26..</SupportedSoftwareVersionLessThan>
Restart the program and itll load in!"
Many thanks!
Message 5 of 11
vinayL7WQ5
Thank you of pointing that out Johnson and I apologize for overlooking the comments sections.
I tried to follow the instructions but I do not have the Threadmodeler folder in the add ins folder although the application is installed in my computer. Am I doing something wrong? Please help.
Thank you
Message 6 of 11
johnsonshiue
Hi! Please look at the path closely . It is not in C:\Program Files\. It is under C:\ProgramData\. Simply copy and paste the path to File Explorer.
Many thanks!
Message 7 of 11
vinayL7WQ5
Sorry. ProgramData folder was hidden in my computer.
Fixed the issues and everything works as expected. Thank you for your help!
Message 8 of 11
mfriederichs
Goodmorning,
Currently i am facing the same issue on my pc. I just updated the latest available version of inventor and the vault. but it cant find either the add in or the vault.
Are there any other options what i can try to make it work?
Message 9 of 11
johnsonshiue
Hi! The Add-In may be hidden. Right-click on the Add-In Manager dialog -> Show Hidden Add-Ins. Or, Vault client was not installed.
Many thanks!
Message 10 of 11
SEC_CAD21
Here is the reply that I received from coolOrange today:
Unfortunately threadModeler is not compatible with Inventor 2021.
I am sorry to inform you that we have decided to not further develop this app meaning we will not release a version that is compatible with Inventor 2021.
We have published the source code for threadModeler on GitHub, this allows users to download it and make the app compatible with Inventor 2021 themselves.
Message 11 of 11
johnsonshiue
Hi! Or, you can change the support version to make it work on Inventor 2021 (see reply #4).
Many thanks!
