i cant use decals and its not showing up
Message 1 of 8
Replies (7)
Message 2 of 8
imajar
Can you share the file?  Unless you can get the decal to work, it wont show up in ray-tracing.
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
Message 3 of 8
im having a little difficulty sending you the file. Im a first time user of inventor. im just not understanding why when I click the image and use decal its not showing up.
Message 4 of 8
imajar
You dont need to try and send me the file directly, instead post in here in the forum, when you compose messages there is a place down below to add attachments.  Put the .ipt part file with the decal there.  (Dont worry about the assembly file)
Aaron Jarrett, PE
LinkedIn
Life is Good.
Message 5 of 8
-niels-
Are you getting any sort of error when trying to apply the image as a decal?
Your image shows that you have the function for decals activated, but you haven't made any selections....
If you select the image and then the face you want to apply the decal to, then hit OK, does it give an error?
If you change the "wrap to face" option when trying to apply the decal, does that help?
Like ajarrett said, unless you have an applied decal, it won't show up in rendering.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 6 of 8
I can't click ok. I've clicked the image and face.
Message 7 of 8
-niels-
I took a slightly better look at your image, i'm seeing the following:
You have a part with just a sketch, which you are editing "in place".
I suspect this is where you have the image for your decal.
This part is inside an assembly, which i suspect contains the part that you want to apply the decal to.
This is not how the decal function works.
You have 2 options:
1. create some geometry in the part with the image to apply the decal to. (preferably the same shape as the actual decal)
Then constrain this to the face at the desired location in the assembly.
2. open the part with the geometry you want to apply the decal to and create the decal in that file with a new sketch containing your image.
(so inside the "GEN1029....etc. file, the multibody, not the assembly)
The decal function only works within a part itself, you can't apply it across parts within an assembly.
Let us know if you can't figure it out.
Niels van der Veer
The Netherlands
Message 8 of 8
problem solved. thanks for you guys help
