chamfer command
chamfer command
evitali
Message 1 of 11
chamfer command
evitali
He.
my question is what action it performs the flag "preserve all features" in the chamfer command?
There seems to be no difference between having the option flagged or unflagged.
It is related to a particular geometry? what? (example, please).
Cheers
Replies (10)
Message 2 of 11
JDMather
What version of Inventor?
Message 3 of 11
evitali
Message 4 of 11
evitali
... but also 2020....
Message 5 of 11
evitali
... and is also an option of fillet command...on 19 and 20
Message 6 of 11
gabrielcabellos_103
Hi man!
"Preserve All Features. When selected, checks all features that intersect with the fillet. Their intersections calculate during the chamfer operation. When not selected, only the edges that are part of the chamfer operation calculate during the operation."
This feature is used when you want to make a chamfer on a face that has other geometries, but you do not want that geometry to change due to the chamfer.
Please accept as solution and give likes if applicable.
*Autodesk Inventor Certified Professional
*Autodesk Fusion 360 Certified User
*Autodesk Student Ambassador
Message 7 of 11
evitali
for instance? have you an image of that kind of geometry? i not the manual explanation, but i am unable to model an example. Thanks and Cheers
Message 8 of 11
evitali
i now ... (sorry)
Message 9 of 11
gabrielcabellos_103
There is an example very similar to a Fillet in this topic: https://forums.autodesk.com/t5/inventor-forum/preserve-all-features-in-fillet-command-doesn-t-work/t...
https://forums.autodesk.com/t5/inventor-forum/preserve-all-features-in-fillet-command-doesn-t-work/td-p/6673855https://forums.autodesk.com/t5/inventor-forum/preserve-all-features-in-fillet-command-doesn-t-work/td-p/6673855
Message 10 of 11
evitali
but it doesnt' work. Flagged or unflagged same final result. See my attached screencast.
Cheers
