Ground Symbol
Ground Symbol
Message 1 of 9
Ground Symbol
Is there a place where I could find a ground symbol in Inventor?
Thank you!
Tom
Replies (8)
Message 2 of 9
JDMather
It is very easy to create symbols.
Message 3 of 9
mikejones
Do you mean like an electrical earthing symbol?
I've used this one in the past. It's an iFeature courtesy of Charles Bliss website http://www.cbliss.com/inventor/iFeatures/index.htm
Mike
Autodesk Certified Professional
Message 4 of 9
mcgyvr
@Anonymous  A 2d line drawing for use in the idw environment or even a part sketch? Or an ifeature/punch to use in the part environment?
There are also at least 4 or 5 "ground" symbols that I am aware of.. Can you show an example of the exact symbol you are looking for in addition to the questions above?
Message 5 of 9
On top of everything else that has been mentioned, I would check out the character map in the text editor.
Message 6 of 9
Thank you all. I ended up creating a symbol.
I thought there might have been a default symbol in the electrical library or the character map. It didn't need to be indented in the ipt, just a call out in the idw.
Tom
Message 7 of 9
Cadmanto
@Anonymous
Have you seen or knew about what I show below?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2021
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 8 of 9
SBix26
@Cadmanto , what font is that?  Is it one that comes with Inventor?
Sam B
Inventor Pro 2021.1 | Windows 10 Home 1903
LinkedIn
Message 9 of 9
Cadmanto
@SBix26 , Yes, but not one of your everyday fonts.
Inventor Pro 2021
Best Regards,
Scott McFadden
