Preserve all features in fillet command doesn´t work
Francisco_García
Mentor Mentor
Message 1 of 11
Francisco_García
Hi.
I have an issue with "Preserve All Features" option of fillet command.
1. If I make a hole or a cut extrusion and keep checked "Preserve All Features" everything works as expected.
2. But if it is any other type of operation it does not work.
This is an alternative version made with extrusion and circular pattern after applying the fillet. The resolution is the same but .... with two more operations.
Does anyone know what I'm doing wrong?
Thanks.
Fco. García Bayarri
Delineante industrial | Formador técnico
LinkedIn | YouTube | Twitter | Telegram
Por favor dame Kudos y marca esta respuesta como Solución Aceptada si responde a tu pregunta.
Please give me Kudos and mark this answer as Accept as Solution if it answers your question.
Replies (10)
Message 2 of 11
Sofia.Xanthopoulou
Hi @Francisco_García,
can you please upload this part, so I use the same date when trying to recreate.
Message 3 of 11
Francisco_García
Thanks for the quick reply, @Sofia.Xanthopoulou.
I attach the file. This is a small test I was doing and I have encountered the problem
Fco. García Bayarri
Message 4 of 11
Sofia.Xanthopoulou
and sorry, forgot to ask - which Inventor Version?
Regards
Message 5 of 11
Francisco_García
Don´t you worry. Mea culpa. Smiley Wink
The version I am working with is 2017.
Fco. García Bayarri
Message 6 of 11
Sofia.Xanthopoulou
Now I see, and I am afraid that this behavior is correct. Inventor cannot add material and if the reference planes disappear somehow (which they do in this example), Inventor cannot recreate the feature.
So, the fillet has to be created before the pin.
I do not understand @Francisco_García, how, the other way round, you would have 2 steps less.
I have attached your file again and added the way I would approach.
If you have any questions, don't hesitate to ask.
Best regards
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Message 7 of 11
Francisco_García
I thought this will be possible seeing this screen capt.
Are you sure you attached the file again? I can´t see it.
Fco. García Bayarri
Message 8 of 11
Francisco_García
Sorry @Sofia.Xanthopoulou ,but I´m still waiting for the file attached 🙂
Fco. García Bayarri
Message 9 of 11
Sofia.Xanthopoulou
Ups, that was not good.....
I was on vacation and didn't realize that my file was not attached - so sorry @Francisco_García.
Here it comes.
Let's continue the conversation to see if we can find an acceptable workflow.
Regards
Message 10 of 11
RobSinglehurst
Interestingly if you use a 6.1251mm fillet in your original file it does work as in the screen capt. you posted. Any larger fillet and it fails. I can't work out why it is failing at that particular size though as it is not a size that works out to be a tangent to the hole etc.
Cheers,
--Rob
Inventor 2024.2
Message 11 of 11
Sofia.Xanthopoulou
you never gave us a feedback on the suggestions. Is something worth being mentioned as accepted solution? If so, go ahead and mark at least one post which you consider a solution Smiley Wink Give all readers the opportunity to benefit from your experience.
If you need further assistance on this, please continue the conversation
Please create a new thread for other questions.
