problem instaling R3
Cris-Ideas
Advisor Advisor
Message 1 of 9
Cris-Ideas
I was trying to install recent R3 update for AI 2017.
I got this.
User I use is user with administrator privileges and I normally install software.
Cris.
Cris,
https://simply.engineering
Replies (8)
Message 2 of 9
mcgyvr
FWIW.. It worked just fine for me..
I installed right from the desktop app without issues..
Message 3 of 9
ChrisMitchell01
Cris - I assume that if you click through the warning that 2017.3 still installed OK You should see build 233 from Inventor help About.
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 4 of 9
Cris-Ideas
I had this sorted out.
Post that only to let you know.
Cris.
Cris,
Message 5 of 9
mcgyvr
Cris.
@Cris-Ideas Cris, What was the solution for you? (just in case someone else comes across your post)
Or was it an "oops.. I'm too embarrassed to say in public" kind of thing Smiley Embarassed
Message 6 of 9
ChrisMitchell01
You simply hit the "Retry" button on the dialog shown below & the install will proceed.
-Chris
Chris Mitchell
Autodesk, Inc.
Message 7 of 9
mcgyvr
-Chris
@ChrisMitchell01  Off topic.. But if the R3 installer read me says you must reboot after installation why does the installer not just do that for you automatically?
Message 8 of 9
ChrisMitchell01
The installer will prompt you to reboot if it's "really" needed. Otherwise the comment in the ReadMe file is a simple good practice.
-Chris
Chris Mitchell
Autodesk, Inc.
Message 9 of 9
Sofia.Xanthopoulou
And the winner is????
Hi guys, which post can be considered "solution" for other readers, or does anyone of you want to make a summary and mark it?
