Inventor Forum
Complex part fixture/holder
9 REPLIES 9
Message 1 of 10
wisniewm
342 Views, 9 Replies
Hi all
I am struggling to create a very accurate fixture/holder for quite a complex part. Please see below:
What I would like to achieve is to make this part lay flat on perfectly fitted holder/fixture and then attache some clamps to hold it in position. Can any one point me into the right direction, please? Thank a lot for any help.
9 REPLIES 9
Message 2 of 10
CCarreiras
in reply to: wisniewm
Hi!
I would use a new file and derive the complex part to this new file.
Then create the support using the derived geometry as reference.
Finally, i would create an assembly with both model and support and apply the clamps.
CCarreiras
Message 3 of 10
TheCADWhisperer
@wisniewm
Can you Attach the file here?
Message 4 of 10
wisniewm
in reply to: CCarreiras
I will try this way. Thanks.
Message 5 of 10
wisniewm
in reply to: TheCADWhisperer
Just for reference, I would like to modify the existing one which is not very well made, see the photo below:
So the green base is fixed to the plate. Everything above that can be replaced.
File to the part attached. Thank you.
Message 6 of 10
JDMather
@wisniewm
What version of Inventor are you using?
Message 7 of 10
wisniewm
in reply to: JDMather
2024
Message 8 of 10
Frederick_Law
First decide where on the part surface you want contact.
Do you want/need contact pad to be same (machined) as the surface?  Or ball contact?
Message 9 of 10
wisniewm
in reply to: Frederick_Law
I want it to be the same, to fit like a glove I would say. Thank you.
Message 10 of 10
Frederick_Law
Make "long" pads and use the part to cut the assembly.
All pads need to be installed on fixture and machine together.
Technology Administrators
