Change projected line colour - drawing sketch
bengee5454
Message 1 of 49
bengee5454
A simple one (hopefully). When working on a drawing, if I want to project the edges of a model in a sketch, the lines are a yellow colour.
This is not very helpful as the background is off-white which makes the lines very hard to see!
How can i change the colour of projected lines?
Replies (48)
Message 2 of 49
ThomasB44
Hi @bengee5454
The color of this line is linked to your application settings / colors.
Just change the colors model here :
Thomas
Mechanical Designer / Inventor Professional 2025
Inventor Professional EESignature
Message 3 of 49
bengee5454
Thanks Thomas,
I had tried that but the projected lines still come out yellow Smiley Frustrated
Message 4 of 49
Roelof.Feijen
And if you really want to create your own Color Scheme, install the usertools from the
C:\Users\Public\Documents\Autodesk\Inventor 2018\SDK folder
and after that run the InventorColorSchemeEditor application from the
C:\Users\Public\Documents\Autodesk\Inventor 2018\SDK\UserTools\ColorSchemeEditor\Bin folder
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Message 5 of 49
ThomasB44
Have you manually changed the color of the line ?
The color of your line is set to "by layer" ?
If you change the colors model in application settings, the default colors of projected lines must change.
Thomas
Message 6 of 49
bengee5454
I have not manually changed the colour
the colour is set to by layer
Message 7 of 49
ThomasB44
That is really strange, I can't figure out how this happen.
Can you share an example of your files ?
Perhaps someone else will find an issue.
Thomas
Message 8 of 49
bengee5454
Here are the files.....any help would be much appreciated
Message 9 of 49
TheCADWhisperer
@Anonymous.gee wrote:
... When working on a drawing, if I want to project the edges of a model in a sketch, ... as the background is off-white .
Can you post screen shot of your Application Options settings for Drafting?
(I show arrow to the Design Color Scheme in this image, but I am interested in the Drafting environment.)
Message 10 of 49
Roelof.Feijen
Your drawing is not an issue. Works fine in Inventor 2017.3
See my screencast
Roelof Feijen
Message 11 of 49
bengee5454
Thank you
Message 12 of 49
qamar.naseem6EVRX
Hi
This seems to work prior to Inventor 2022, but could you try this in IV 2022. I have millenium background as choice for Design display., when creating a sketch in a drawing, lines still remain yellow, even when other color schemes are used.
Message 13 of 49
DRudaz
For me this is a bug of version 2022 because on previous versions it worked. Normally it is the color of the reference curve that manages this color in the color scheme.
I have found a workaround to this problem. After having projected the geometry I select all the elements and I go to Format and I change the color of according "to layer" to the color of my choice. Or you can make this operation before project the gemetry.
Salutations,
Dominique
Autodesk Certified Instructor - Gold / Inventor Certified Professional
Message 14 of 49
johnsonshiue
Hi Folks,
I am sorry I am a bit confused here. The In-Canvas Color Scheme has pre-defined object colors. You can change it in the Color Scheme editor to persist. Is it not working? I am not sure why you need to change the sketch curves color format.
Many thanks!
Software Test Engineer
Message 15 of 49
DRudaz
Hi Johnson,
Quite simply because the lines in yellow are not visible correctly. And in version 2022 we cannot change it.
Salutations,
Dominique
Message 16 of 49
johnsonshiue
Hi Dominique,
If possible, do you mind sharing a video or screencast showing the behavior? I am not able to reproduce it on my machine. Please make sure graphics driver is updated and all critical Windows updates are installed.
Many thanks!
Message 17 of 49
DRudaz
Hi Johnson,
here is the screancast
Screancast
Salutations,
Dominique
Message 18 of 49
johnsonshiue
Hi Dominique,
Many thanks for sharing the video! I got better understanding now. It is about the drawing sketch line color. It does look like a bug. I will work with the project team to understand it better.
Thanks again!
Message 19 of 49
johnsonshiue
Hi! This has been reported as INVGEN-54411.
Many thanks!
Message 20 of 49
MJH_
Hi Johnson, is there an ETA on when this bug fix will be available? I've just stumbled across this issue myself.
