Inventor Forum
automating exporting/importing true/false parameters
11 REPLIES 11
Message 1 of 12
janrienk
2039 Views, 11 Replies
Re-using (true/false) parameters in different parts/assemblies is something that I do a lot. I repeat the same process over and over, and since [this idea] isn't a thing yet (support is appreciated), I'm looking for a smarter/faster way to do this.
What I'm doing currently is this:
  1. make boolean parameter has_feature_x in source file
  2. check key behind parameter
  3. add parameter to form
  4. make numerical counterpart has_feature_x_num
  5. convert boolean to numerical with iLogic:
    If has_feature_x Then
        has_feature_x_num = 1
    Else
        has_feature_x_num = 0
    End If
  6. check export behind numerical parameter
  7. link source parameter in destination file
  8. make boolean parameter has_feature_x in destination file
  9. convert back to boolean (iLogic) in destination file:
    If has_feature_x_num = 1 Then
        has_feature_x = True
    Else
        has_feature_x = False
    End If
  10. write iLogic rule in destination file for feature manipulation:
       Feature.IsActive("feature_x") = True
    Else
       Feature.IsActive("feature_x") = False
    End If
What would be sensible steps to automate this process?
I was thinking about making something that I could use like this:
exportParameter(has_feature_x)
It would have to:
- makes numerical counterpart if it doesn't exist
- marks numerical counterpart for exporting if it isn't yet.
- gives the numerical counterpart the right value.
Similar Idea for importing, but I'm sure I'll figure that out once I have the exporting going.
I've never made a sub though, and I'm not sure how to go about this. So an example would be hugely appreciated.
And of course, if you have a better Idea how to go about this please share.
Thanks!
11 REPLIES 11
Message 2 of 12
PaulMunford
in reply to: janrienk
I'm confused, do you want to Export and then Import Parameters?
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014...
Do you want to link parameters?
Parameter("Frame Skeleton Example:1", "Part_TF") = Assy_TF
Perhaps you could explain the gola and then we couls suggest an alternative method?
Autodesk Marketing Manager D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
Message 3 of 12
janrienk
in reply to: PaulMunford
My goal is to manipulate my assemblies and parts from one location with less of a hassle. The way I do this now is using an ipt file (that's not in the assembly) as a master file. (If I use the assembly to modify a part and then put it in the assembly Inventor claims it can't do that because of a (possible) circular reference.) Perhaps exporting/importing aren't the right words to use, it is about linking parameters. I just called it exporting/importing since I wasn't able to link them the way I'm able to link numerical parameters.
Your (linking) suggestion sounds promising, I will try that. Thank you.
Message 4 of 12
MechMachineMan
Another alternative:
Step1: Drive your sub-models using named parameters.
Step 2: Write code that pulls all named parameters into top level as user params
Step 3: Write iLogic code that pushes all of the user parameters from the top level to all sub-levels over the params of the same names.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 5 of 12
janrienk
@PaulMunfordI've tried linking the parameters on the top assembly and it works like a charm, thank you!
  • Inventor doesn't whine about circular references when you link the parameters in the assembly code (it does when you're linking from the parameter window in the part)
  • It's also faster than using a master part because I don't have to switch windows to see the result, and there seems to be no need for updating the assembly. (I used to have to update the assembly twice for certain changes).
@MechMachineManThank you for the suggestion. This definitely sounds like where I would eventually like to end up! I'm not sure how to go about this yet though. Will do some research on this. Pointers to useful building blocks for this would be greatly appreciated.
Message 6 of 12
PaulMunford
This class at Autodesk University online might give you a few ideas 😉
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2013/product-design-suite/ma2604#ch...
Paul
Message 7 of 12
janrienk
@PaulMunfordWill check it out, thank you!
Message 8 of 12
janrienk
@PaulMunfordGreat talk! Very informative/inspiring. (And good to see I'm not the only one who thinks giving features and parameters a proper name is good practice)
The 'Dims' rule seems to be exactly what I need right now. I've cut all the parameter-interface links to my master part, and intend to drive everything from the top assembly. (the broken links leave convenient handles in the respective parts/ sub-assemblies) I can't get it to work though, and since I can only see the top half of the code in the video (and I can't find it in the handout) I'm afraid I've missed something. Would you be willing to share? Thanks.
Message 9 of 12
PaulMunford
Sure,
We've worked on the routine a little since then.
This iLogic Code will create a list of all parameters that exist in the Assembly, that start with 'A_' (This allows you to make parameters 'Local' or 'Global).
It will then iterate through all parts in the assembly. In each part it will make a list of all part parameters that start with 'A_'.
If it can find a parameter in the assembly, that has a matching parameter in the part, it will 'push' the value of the assembly parameter down into the part.
The 'Trigger Generator' rule is just a helping rule. This just creates a list of all assembly parameters inside a rule called 'Trigger'. As long as parameters are listed inside an iLogic rule, updates to the parameter values will happen instantly.
You need to run the Trigger Generator rule whenever you add a new parameter to the Assembly parameters table.
Is that helpful?
Dim oAsmDoc As Inventor.AssemblyDocument = ThisDoc.Document
Dim oPars As Inventor.Parameters = oAsmDoc.ComponentDefinition.Parameters
Dim oList As Collection = New Collection
For Each oPar As Inventor.Parameter In oPars
    If (Left(oPar.Name, 2) = "A_") Then
        oList.Add(oPar.Name)
    End If
Next
If oList.Count = 0 Then
    MsgBox("Empty list :(")
Else
    'print oList content for debug purposes
    'Dim sTotal As String = "Found:  " & oList.Count
    'For Each st As String In oList
     '   sTotal += vbNewLine & st
    'Next
    'MsgBox(sTotal)
    'now we can do something useful with names in the oList
    For Each oOcc as ComponentOccurrence In oAsmDoc.ComponentDefinition.occurrences
        For Each ParName As String In oList
	  Try
                Parameter(oOcc.Name, ParName) = Parameter(ParName)
					  Catch
	  End Try
        Next
    Next
End If
'Update the document to see the changes
iLogicVb.UpdateWhenDone = True
Tags (2)
Message 10 of 12
janrienk
Dear @PaulMunford If there was a "give bucket full of kudo's" button I'd hit it. Thank you!
The code I got from the presentation seems to work now (it didn't work upon 'run rule', but it did when I changed the parameter in question). I will test your new routine, and adapt it as soon as I get it to work.
Message 11 of 12
janrienk
And again, it works like a charm.
Here is a slight modification that perhaps you might find useful:
'[ DEBUG
	If debug Then
		'Print oList content For debug purposes
		Next
		MsgBox(sTotal)
	End If']
the '[ and '] make the code collapsable, and the If statement enables you to turn on/off all debug code by setting the parameter "debug" to True or False
Message 12 of 12
janrienk
@PaulMunfordI took the code for a little spin, and I understand what happens now. It doesn't work for parameters in subassemblies. So I thought I'd fix that, by having the same rules in the subassemblies and firing them in a similar way (determine which parts are assemblies and firing running the rules from the top assembly. (At one point I was even thinking about having the assemblies passing their own code down to the subassemblies so that I'd only have to put the code into a top assembly.)
Although I still like the idea, things were starting to slow down. It started to take up to 20 seconds to change the parameters directly. Probably because of all the loops it was going through. So changed my form to change them upon hitting Done or Apply. That wasn't in line anymore with the whole idea of directly seeing what you're doing though. So for performance reasons I'm now setting all the parameters using the Parameter()function directly.
So I've learned a lot, said goodbye to the hassle of managing all the links the way I used to with a master part, and I'll probably pick this up again later.
