Hi
Is it possible to apply a Gradient Color to a section on a part?
The attached image example shows a light blue at the start and ends with a darker blue
INV2019
Cheers
JS
As this thread suggests, adjusting the lighting.
Or, another thought is to create a decal with the gradient in it and apply that in the part model.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
You can make a gradient color in the appearance editor.
The gradient only works under the "realistic" visual style though.
Some work would need to be done to apply it to a specified section, using "split" comes to mind and then you'd have to scale the appearance properly.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
