I am making an exploded view of a cutting fixture and need to simplify fastener identification. In the .iam I made all like fasteners the same color (ie. 1/4-20 x .5 SHCS all red, 1/4-20 x .75 SHCS all blue etc). When I went into the .ipn the colors have all remained gray. Is there any way to make that color change show up in the .ipn?
Randy Martens
Inventor 2013 Professional
Change at the part level.
Make your color changes within the Studio enviroment, they will stick in the IPN enviroment and you will still keep your original IPT color for other work.
Hi Guys thanks for the advice. I can't change the color at the part level in this case. I need the color coding at the assembly level not per part, I'd run out of colors in a hurry if I tried to uniquely color every different size of SHCS. Also with the fasteners being content center parts changing properties would be a bit more work than I want to undertake. We build one-off jigs and fixtures and I am trying to make fastener selection easier for my machinists by color coding them so they can easily tell what goes where on the exploded drawing. If I color it in studio can I select all occurrences like I can in the assembly level and can I make a ballooned drawing of it as final output?
Randy
Yes,
Open your IAM, switch into the Studio enviroment, color your items as required, the colors will only be in the IAM enviroment.
Then create your IPN of the IAM with your exlosions, load the IPN as normal into your IDW and ballon as normal. All items will carry the color from the IAM, colored within the Studio enviroment.
