Inventor Forum
SAVING A NEW TITLE BLOCK
4 REPLIES 4
avaya2012
964 Views, 4 Replies
I have been using Inventor for about 4-5 years now but have dealt very little with modifying and updating title blocks.  We have a custom title block that we have been using but it is now time to get it updated.
I saved the existing title block as a new template simply as a test title block to play around with. When I create an .idw and look at the browser it is still referencing the old title block called Title Block 1.  I am afraid if I make any changes to the title block it will mess up our current title block.  Is this correct?  Am I missing a step somewhere?
4 REPLIES 4
Hi avaya2012,
To create a new TB, just edit the existing one, make changes and then right click and choose Save Title Block. You'll be given the opportunity to Save As in order to create a new one.
I hope this helps.
Curtis
I got that far and figured out but I do not know where it is saving it.  I clicked save as..then typed my new name and save.  After that I dont know where it is.  The title block I am in still has the old title block name in it.
msklein
in reply to: avaya2012
Delete the title block out of your format and then insert your new one then just save the templet. After verifying  new title block works delete all traces of old title block, should be fine from here on out.
MSK
avaya2012
in reply to: msklein
I finally got it figured out.  I was making it more difficult than it was.
