Adaptive Extension Spring - Closed Loop Breaks
dragonxflyer
Observer Observer
dragonxflyer
Observer
Observer
Hello Community,
I am trying to build an adaptive extension spring with closed loop ends.  Building the adaptive spring part was easy but for some reason my closed loop ends break when I stretch the spring.  I have been toiling with this problem for over and hour now with no success.  When I created the closed loops I used a 3D sketch to Project to Surface my 2D sketch onto an arched plane which builds the helical curve, then using Sweep to create the wire.  When the break occurs I can re-enter the Sweep and show it the correct path which fixes it, but as soon as the spring extends it breaks again.  I know the problem must be the Project to Surface function because of the path it follows when it breaks, I have tried additional constraints, I even tried making the ExtrusionSrf adaptive but with no luck.
Any suggestions would be appreciated!
johnsonshiue
Hi! Please share the file here or send it to me directly at johnson.shiue@autodesk.com. I would like to understand the Adaptive behavior better.
Many thanks!
Software Test Engineer
