Different Revision Table on each sheet on a drawing.
dleigh2GBTW
dleigh2GBTW
Hi all
Is there a way to have different revision table for each sheet in a drawing. I know that when you place a revision table on the sheet you select "Active Sheet" but this only changes the rev number. Lets say I have the description of the table linked to a iProperty, If you create a new revision row on sheet 1 (Say this is going from rev 1 to rev 2,) and change the iProperty description the old description on sheet 1 will say, but on sheet 2 the description changes when it should stay the same. anyone have a way to have this all work.
Donald
johnsonshiue
Hi! If it is linked to an iProperty value, it will be document-specific, not sheet-specific. Or you will need to create multiple iProperties to account for each sheet.
Many thanks!
Software Test Engineer
