3D PDF error
This widget could not be displayed.
3D PDF error
I use Inventor professional 2021 and get an error on creating 3d pdf. I get the error with an assembly, but also with even one part. Inventor also gives the error if I try to create the 3D pdf from a file on the local disc (desktop)
I attached the error message. Any help would be wonderful.
Greetings, Koen Hermsen
Replies (18)
bradeneuropeArthur
Could you try to test it with a file that is not on a server!?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
I tried, that works. Another assembly with a different project file works fine from the same server. I copied the project file but the problem continues to exist. Even a part in the project will not export to 3d pdf.
bradeneuropeArthur
where are the pdf template files stored?
Arthur Knoors
They are stored on the server as well. But the test from the desktop used the pdf template from server as well.
With the pdf template coming from the program files folder it does not work either.
bradeneuropeArthur
Try to use them / template pdf files from Local directory.
Arthur Knoors
Does not work either.
bradeneuropeArthur
Can you make a screenshot of the settings you are using when the pdf is to be created.
I mean the dialog with settings.
Arthur Knoors
see attached...
bradeneuropeArthur
You have tried an local location for the Output, isn't it?
Arthur Knoors
yes, that is correct
bradeneuropeArthur
are you having problems with all files, or can you create pdf from other files?
Arthur Knoors
bradeneuropeArthur
Arthur Knoors
I can create a 3d pdf from other files with a different project file. I am on Inventor 2021.3.1.
I can also create a 3d pdf from a derived part of the assy in the same project file, location, etc. It looks to me that one or multiple parts/assys are the cause of the error.
bradeneuropeArthur
can you show the differences in the project file?
Arthur Knoors
Well, the most weirdest thing happened. It works again.
There are no differences in project file. I updated my adobe reader from pro 9 to pro DC and now it seems to work again. What I do not know is why it did not work.
bradeneuropeArthur
Means that the update solved it for you.
Good to hear.
Arthur Knoors
yes and thank you for your help !
bradeneuropeArthur
Arthur Knoors
