Inventor Forum
2D environment
3 REPLIES 3
360 Views, 3 Replies
2D environment
Hi
I produce 2D plan of elevator design. I use AutoCAD but for each plan I have to design from beginning.
Is there any specific environment in Inventor to design easier?
You can see 2 different drawings in photos but there are more than 2 plans.
3 REPLIES 3
mdavis22569
Hi @Anonymous
Is there ANY 3D on your files at all?
If the answer is no, then Inventor likely won't be a better software for you. AutoCAD would be.
If you have 3D and it's usually always the same with some minor changes. You could model it up in 3D making it a standard starting point with an associate 2D file.
Then when you need to make a new Elevator you just start with those templates... Updating - Changing what you need to.
Mike Davis
johnsonshiue
Hi! I will leverage DWG Underlay workflow. In Inventor, start a new part -> Import -> pick the AutoCAD dwg file -> pick an origin plane (XY) and the origin to place the dwg geometry. After that, you can create a 2D sketch and use Project DWG Geometry (under Project) to project the dwg geometry to the sketch.
Another way is simply build it from scratch. You can open the dwg file in Inventor as a reference. You can measure or get the dimension. But, largely you create parts from scratch.
Many thanks!
Software Test Engineer
lena.talkhina
Hello @Anonymous  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Technology Administrators
