Inventor Forum
2010 Crash
28 REPLIES 28
Message 1 of 29
1108 Views, 28 Replies
2010 Crash
I just switched back to the ribbon because the help file references it
extensively. Now 2010 crashes randomly and there is no popup to send
information to Adesk. So I've read that the ribbon has caused problem with
2010 on some 32 bit systems. Is there any more information on a fix or a
hope of one. Should I give up on the ribbon and the help file (rather new
with Inventor)?
Rich
2010 Crash
with Inventor)?
Rich
28 REPLIES 28
Message 2 of 29
johnsonshiue
johnsonshiue
Rich,
If you have reproducible steps to the crashes, please let me know.
Many thanks!
johnson.shiue@autodesk.com
Software Test Engineer
Rich,
Many thanks!
Message 3 of 29
The only thing reproducible so far is that I can't
remember when I had a crash before going back to the ribbon. Start there and on
my end I'll see if I can remember how to create a crash!! If it crashes again
I'll dump the ribbon again and see if things clear up.
Rich
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
Rich,
If you have reproducible steps to the crashes, please let me know. Many
thanks! johnson.shiue@autodesk.com
Rich
Rich,
Message 4 of 29
mcgyvr
mcgyvr
I too had issues with the ribbon causing crashes.. I have reported them already. It was in the idw environment.
But I switched back to classic and couldn't be happier. The ribbon as it stands in 2010 is a joke. Like others have said the day they discontinue the classic interface is the day I stop paying for subscription and stay with that release for ever.
Message 5 of 29
johnsonshiue
johnsonshiue
Hi! Could you send me an email so I can track the report?
Thanks!
Thanks!
Message 6 of 29
Yes I was in the IDW enviroment when it happened,
about 30 minutes in on a part with a lot of features!
Yes I might dump the ribbon but as useless as the
help file is most times you should try to use it with out the ribbon. All it
refers to is where to find the command in the ribbon and ribbon only! I'm still
at the point where I need help from time to time. They should offer a help file
that well helps and then offer another flavor with out the ribbon. Both might be
asking too much though?
Rich
I
ever.
Rich
I
ever.
Message 7 of 29
There was no report I was told by Vista that the
program had to close I clicked OK and I was looking at my empty
desktop.
Rich
Hi!
Could you send me an email so I can track the report? Thanks!
desktop.
Rich
Hi!
Message 8 of 29
brian.cranston
brian.cranston
Are you running a 3dConnexion device? There are some reports of crashes with Inventor and the ribbon using the latest driver. I had crashes with Inventor and AutoCAD Mechanical concurrent (both 2010) while using the 3.7.12 driver. I had to go back a driver release to solve. But since then my workstation drive failed and I've had no issues with 3.7.12 on the new rebuild of XP.
http://www.3dconnexion.com/forum/viewtopic.php?t=2912
-Brian Cranston
-Brian Cranston
Message 9 of 29
Yes with the latest driver, latest driver for video
card latest everything. The only thing that changed is me going back to the
ribbon.
Rich
Are
http://www.3dconnexion.com/forum/viewtopic.php?t=2912 -Brian
Cranston
ribbon.
Rich
Are
Cranston
Message 10 of 29
brian.cranston
brian.cranston
Can you try the 3.6.11 driver and the ribbon?
http://www.3dconnexion.com/support/get_driver.php/3DxSoftware_v3-6-11.exe?host=216.110.190.130&path=/support/drivers&loc_id=2&driver_id=97&file_id=407&f_name=3DxSoftware_v3-6-11.exe&prod_id=11&os_id=4
-Brian
-Brian
Message 11 of 29
qiho
qiho
Archived Account
Yes, We've seen this issue via the error reports. Can anyone reproduce it with 3D mouse? Edited by: qiho on Jun 18, 2009 3:17 AM
Message 12 of 29
michael.huang
michael.huang
Hi Rich,
Have you tried the 3.6.11 driver with the ribbon? I want to know if Ribbon UI works well with previous 3dConnexion driver.
-Michael
Hi Rich,
-Michael
Message 13 of 29
I can't find the 3.6.11 driver as all Connexion has
is the latest. I'm not a beta tester.
Hi
Rich, Have you tried the 3.6.11 driver with the ribbon? I want to know if
Ribbon UI works well with previous 3dConnexion driver. Thanks,
-Michael
Hi
-Michael
Message 14 of 29
brian.cranston
brian.cranston
Try the link in my June 5, 2009 4:24 PM posting. Or on their driver page, in step two, click "Archive (Legacy Software)".
-Brian Cranston
-Brian Cranston
Message 15 of 29
I've run both versions of the driver and I've found no difference. The ribbon just doesn't play nice.
I really wonder how well the software is tested before being released. This is a standard setup.
Message 16 of 29
michael.huang
michael.huang
Hi Rich and jpealo,
Could you recall some previous steps before the crash? For example, if editing a 2D sketch, or editing sub-assembly, or set Ribbon as "minimize to panel titles", or minimize/restore application window, if use Vault addin, doing some Ribbon UI customization, etc.
What we know is this defect will happen on a 3Dx device and Ribbon UI. Rotating 3Dx mouse will make Ribbon UI being update at times. At some time, Inventor will crash.
Any of your information will greatly help us to position this defect.
-Michael
Hi Rich and jpealo,
-Michael
Message 17 of 29
I really can't point to anyone thing that causes the error as it has been different every time. You might look at constraint placements, working without saving for around 10 to 20 steps (this isn't even close to a memory issue for us). We had one crash copying a sketch from one file to another. Rotating constantly with the 3Dx device might be another.
I hope this helps.
I hope this helps.
Message 18 of 29
qiho
qiho
Archived Account
Hi Rich,
could you please try to unload the "3DxInventor" addin in Inventor addin manager, and see whether or not Inventor will crash under the new ribbon UI?
Steps to unload "3DxInventor"
1 Launch Inventor
2 Click "Add-Ins" in "Tools" tab -> "Options" panel
3 Select "3DxInventor" addin in "Add-In Manager 2010" dialog
4 Uncheck "Loaded/Unloaded" and "Load On Startup" check boxes and click "OK"
5 Restart Inventor. Edited by: qiho on Jun 19, 2009 5:59 AM
Hi Rich,
1 Launch Inventor
Message 19 of 29
No. I've given up on the ribbon and I have work to
do.
Rich
Hi
Rich, could you please try to unload the "3DxInventor" addin in Inventor addin
Steps to unload "3DxInventor" 1 Launch Inventor 2 Click "Add-Ins" in "Tools"
tab -> "Options" panel 3 Select "3DxInventor" addin in "Add-In Manager
2010" dialog 4 Uncheck "Loaded/Unloaded" and "Load On Startup" check boxes and
click "OK" 5 Restart Inventor. Edited by: qiho on Jun 19, 2009 5:59
AM
do.
Rich
Hi
AM
Message 20 of 29
brian.cranston
brian.cranston
3Dconnexion put a new driver out today. It includes Inventor stability improvements.
http://www.3dconnexion.com/support/downloads.php
