style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
"johnsonshiue" wrote in messageRich,
href="news:6196720@discussion.autodesk.com">news:6196720@discussion.autodesk.com...
If you have reproducible steps to the crashes, please let me know. Many
thanks! johnson.shiue@autodesk.com
"mcgyvr" wrote in messageI
href="news:6196687@discussion.autodesk.com">news:6196687@discussion.autodesk.com...
too had issues with the ribbon causing crashes.. I have reported them already.
It was in the idw environment.
But I switched back to classic and
couldn't be happier. The ribbon as it stands in 2010 is a joke. Like others
have said the day they discontinue the classic interface is the day I stop
paying for subscription and stay with that release for
ever.
"johnsonshiue" wrote in messageHi!
href="news:6196731@discussion.autodesk.com">news:6196731@discussion.autodesk.com...
Could you send me an email so I can track the report? Thanks!
"brian.cranston" wrote in messageAre
href="news:6196771@discussion.autodesk.com">news:6196771@discussion.autodesk.com...
you running a 3dConnexion device? There are some reports of crashes with
Inventor and the ribbon using the latest driver. I had crashes with Inventor
and AutoCAD Mechanical concurrent (both 2010) while using the 3.7.12 driver. I
had to go back a driver release to solve. But since then my workstation drive
failed and I've had no issues with 3.7.12 on the new rebuild of XP.
http://www.3dconnexion.com/forum/viewtopic.php?t=2912 -Brian
Cranston
"Michael.Huang" wrote in messageHi
href="news:6202283@discussion.autodesk.com">news:6202283@discussion.autodesk.com...
Rich, Have you tried the 3.6.11 driver with the ribbon? I want to know if
Ribbon UI works well with previous 3dConnexion driver. Thanks,
-Michael
"qiho" wrote in messageHi
href="news:6204899@discussion.autodesk.com">news:6204899@discussion.autodesk.com...
Rich, could you please try to unload the "3DxInventor" addin in Inventor addin
manager, and see whether or not Inventor will crash under the new ribbon UI?
Steps to unload "3DxInventor" 1 Launch Inventor 2 Click "Add-Ins" in "Tools"
tab -> "Options" panel 3 Select "3DxInventor" addin in "Add-In Manager
2010" dialog 4 Uncheck "Loaded/Unloaded" and "Load On Startup" check boxes and
click "OK" 5 Restart Inventor. Edited by: qiho on Jun 19, 2009 5:59
AM
