Part Quantities Per Assembly
andrewdroth
Advisor Advisor
Message 1 of 28
andrewdroth
Hey all,
We have a client that has requested that our shop drawings follow a standard that is slightly different from the one we're familiar with.
Each part file for the project will get it's own drawing and special qty field.
The QTY field will list the number of instances per assembly, and the total number per project. I think this will look something like this.
A1001(6), A1007(2), A1015(3)
TOTAL QTY: 11
My intention it to run an iLogic code from the top level assembly that dives down and adds the QTY's for each part as a custom iProperty that can then be linked in the drawing.
I found this bit of code here that is close to what I would need, but doesn't differentiate sub assembly quantities.
http://forums.autodesk.com/t5/inventor-forum/multiple-sub-assemblies-in-a-parts-list/td-p/4342872
Sub Main ()
	If iProperties.Value("Project", "Project")=""
		oProj = InputBox("Change Project Name", "Project Name", iProperties.Value("Project", "Project"))
		iProperties.Value("Project", "Project")=oProj
	End If
'get the project number of this assembly and use it to build the name of a custom property, i.e. "4100_QTY"
customPropertyName = CStr(iProperties.Value("Project", "Project")) & "_QTY"
	oQ=MessageBox.Show(customPropertyName, "Project Number",MessageBoxButtons.YesNoCancel,MessageBoxIcon.Question)
		If oQ=vbYes
		oDone()
		ElseIf oQ=vbNo
		Call oProject
		ElseIf oQ=vbCancel
		MessageBox.Show("Cancelled", "Completed", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
		Return
	End If
End Sub
Sub oDone
oCompDef = ThisDoc.Document.ComponentDefinition
openDoc = ThisDoc.Document
'Let's open the document that inventor has in focus right now
'Let's check to make sure that it's an assembly document.
'We don't want to run this on just a part document as it -
'will have none of the required information!
If openDoc.DocumentType = kAssemblyDocumentObject Then
    'If it is an assembly document, then we need to get a collection
    'of all the documents that are associated to it.
    'the following line actually does that, while at the time time
    'starts the loop to look at each one of those documents.
    'imagine that it's written out in this way :
    'For each Document file in the collection of ALL the document
    'files that are in this open document, do the stuff below...
    For Each docFile In openDoc.AllReferencedDocuments
        'First thing first, we need to make a string that can represent the
        'document that we're working on. This way it will be easier to
        'call on that document when we want to make changes to the iproperties.
        'this is no different than if you just typed out :
        'iProperties.Value("Part_Name_Here.ipt", "Project", "Authority")
        'But because we are doing this dynamically, we don't have to type that
        'about line out for every single part that is in the document.
        'FNamePos is getting the number of spaces that it takes to get to the
        'very last back slash in the full file name of our document.
        FNamePos = InStrRev(docFile.FullFileName, "\", -1)
        'We can then take that number (position) and use it to cut off all of the
        'file path that we don't need. In this case, it's the front of the path
        'that we're getting rid of, leaving us with just the file name.
        docFName = Mid(docFile.FullFileName, FNamePos + 1, Len(docFile.FullFileName) - FNamePos)
        'Let's make sure that we can even change this part. If we can, then we'll continue.
        If docFile.IsModifiable = True Then
            'Because you can only grab the occurrences from an assembly document
            'we need to fill up that empty AssemblyDocument container with an object
            'that we know is definitely an assembly document. Because that was one
            'of the first checks we made up there on this open document, we can safely
            'declare that assemblyDoc (Which is an AssemblyDocument) is equal to
            ' openDoc (Which is just a regular old Document)
            assemblyDoc = openDoc
            'While we're at it, let's go on and define the empty ComponentDefinition container
            '(we named ours assemblyDef) with some sort of content.
            assemblyDef = assemblyDoc.ComponentDefinition
            'Now we need to collect every instance of the document against
            'our open assembly and put them all inside of partQty.
            partQty = assemblyDef.Occurrences.AllReferencedOccurrences(docFile)
                'Now that we have our collection of instances, we need to populate
                'our target iproperty with the total amount.
                'Instead of just throwing that amount in there, let's make sure that
                'the value inside of the target iProperty isn't already equal to our count.
                'If it is equal, then we don't have to change anything (which saves us time!),
                'but if it isn't equal then we will need to change it.
                'The Try statement is here because of the next if statement ---
                'If partQty.Count <>  iProperties.Value(docFName, "Project", "Authority") Then'
                'If we just compare the two values, there is a small chance that our target
                'iProperty is already set to something that is NOT a number, which would create
                'an error (as you can't compare numbers against things that aren't numbers).
                'So, we TRY to complete that if statement, and if there is an error (The CATCH)
                'we just force that target to equal our part qty total.
                Try
						If partQty.Count <>  iProperties.Value(docFName, "Custom", customPropertyName) Then
						iProperties.Value(docFName, "Custom", customPropertyName) = partQty.Count
                    End If
                    Catch
                End Try
        End If
    Next
Else
'This is here to warn the user that they are attempting to run this in a document that is invalid!
'we don't want them running things that aren't correct! Force them to obey!
MessageBox.Show("You must have a valid Assembly document open before using this code!", "File Type Mismatch!",MessageBoxButtons.OK,MessageBoxIcon.Exclamation)
End If
iLogicVb.UpdateWhenDone = True
MessageBox.Show("Completed", "Completed", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
End Sub
Sub oProject
	Main ()
End Sub
Any tips on how to concatenate the per assembly quantities into one field?
Thanks in advance!
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
Replies (27)
Message 2 of 28
MechMachineMan
Method 1:
1) Iterate through ALL ref'd docs of top level.
2) Iterate through ALL Referencing Docs of this sub-doc.
3) In each assy it occurs in, count the amounts of times it occurs. - May need additional filtering to check if any of the occurrences are Reference BOMStruct.
4) Keep a running tally, and also use a separate string to summarize results of the assembly usage
5) Output this info into the iProp stored in that part.
*This will likely really only work if all of the assemblies that use these parts are compiled into a general assembly, and will not work for sub-assemblies.
Method 2:
1) Iterate through BOM,
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 28
andrewdroth
@MechMachineMan wrote:
Method 1:
Yeah, all the assemblies are typically put in one 'Parts List' top level assembly for a complete BOM for the project, so this would work fine.
Do you know what the iLogic code for the summarized results would look like?
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 4 of 28
MechMachineMan
Yeah, fairly well. Just would take time that I do not have until later this evening. But here is the start of the idea behind that method.
Sub Main()
        Dim oDoc As Document = ThisApplication.ActiveDocument
        For Each oSubDoc in oDoc.AllReferencedDocuments
               Call PopulateAncestryProp(oSubDoc)
        Next
        MsgBox("Rule Complete!")
End Sub
Sub PopulateAncestryProp(oSubDoc As Document)
        For Each oParentDoc in oSubDoc.ReferencingDocuments
                 oThisCount = GetParentNonRefCount()
                 oThisPN = ...Property("Part Number").Value
                 oTotalCount = oTotalCount + oThisCount
                 oAncestryString = oAncestryString & oThisP/N & oThisCount
        Next
oSubDoc.PropertySets("Inventor User Defined Properties")("AncestryStr").Value = oAncestryString End Sub
Function GetparentNonRefCount(oSubDoc As Document, oOccDoc As Document)
For Each oOcc in oSubDoc.Occurrences.AllReferencedOccurrences(oOccDoc)
If oOcc.BOMStruct <> Ref
oCount = oCount + 1
End if
Next
Return oCount
End Function
Justin K
Message 5 of 28
andrewdroth
Excellent Thanks!
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 6 of 28
rhasell
Hi
It does subs for me?
Perhaps I miss read your question?
Edited:
Okay, perhaps I did miss read, The code only does total quantity per project.
Reg
2026.1
Message 7 of 28
MechMachineMan
Give this a whirl. Let me know if anything isn't working for you.
VBA & vb.net versions included.
'AncestryiPropRule in VBA
'by MechMachineMan via AutoDesk InventorCustomization Forums
'Feb 06, 2017
'Purpose: Iterates through all children documents of a main assembly and adds their "Where Used" and
'         "Qty" information to the children for use on a drawing.
'Notes: End user will need to use the Custom iProps "_AncestryStr" and "_TotalCount"
'Rev 0: As released to forums
Sub Main()
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSubDoc As Document
    For Each oSubDoc In oDoc.AllReferencedDocuments
    Next
    MsgBox ("Rule Complete!")
End Sub
    Dim oTotalCount As Integer
    oTotalCount = 0
    Dim oThisPN As String
    Dim oAncestryString As String
    oAncestryString = ""
    Dim oParentDoc As Document
    For Each oParentDoc In oSubDoc.ReferencingDocuments
        oThisCount = GetParentNonRefCount(oParentDoc, oSubDoc)
        oThisPN = oParentDoc.PropertySets("Design Tracking Properties")("Part Number").Value
        If oAncestryString = "" Then
            oAncestryString = oThisPN & "(" & oThisCount & ")"
        Else
            oAncestryString = oAncestryString & ", " & oThisPN & "(" & oThisCount & ")"
        End If
    Next
    On Error Resume Next
        oSubDoc.PropertySets("Inventor User Defined Properties").Item("_AncestryStr").Value = oAncestryString
    If Err.Number <> 0 Then
        Call oSubDoc.PropertySets("Inventor User Defined Properties").Add(oAncestryString, "_AncestryStr")
    End If
        oSubDoc.PropertySets("Inventor User Defined Properties").Item("_TotalCount").Value = oTotalCount
        Call oSubDoc.PropertySets("Inventor User Defined Properties").Add(oTotalCount, "_TotalCount")
    End If
End Sub
Function GetParentNonRefCount(oParentDoc As Document, oOccDoc As Document) As Integer
    For Each oOcc In oParentDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(oOccDoc)
        If oOcc.BOMStructure <> BOMStructureEnum.kReferenceBOMStructure Then
            oCount = oCount + 1
        End If
    Next
    GetParentNonRefCount = oCount
End Function
In vb.net:
(note, IN THIS CASE, all I had to do to convert from VBA to vb.net was remove "Set" where it appeared, and change "
GetParentNonRefCount = oCount   <- (vba)  TO  (vb.net) ->  Return oCount
Code:
'AncestryiPropRule in vb.net
'Feb 06, 2017
Sub Main()
    Next
End Sub
    oTotalCount = 0
        Else
        End If
    Next
    End If
    End If
End Sub
            oCount = oCount + 1
        End If
    Next
    Return oCount
End Function
Justin K
Message 8 of 28
LukeDavenport
I'd first check to see whether you can use the built-in 'Parts Only' BOM
for simplicity. That'll sum all the parts in the whole assembly.
Luke
Message 9 of 28
MechMachineMan
It sounds like he wants ancestry tags (or whatever you want to call them), especially if it's based off of a client standard, which unfortunately has no built-in functions in Inventor 😞
To add, to use the macro/rule I wrote, you will need to call off the custom iProperties "_AncestryStr" and "_TotalCount" from the part model in your drawing.
Justin K
Message 10 of 28
andrewdroth
Exactly. We have been using parts only to wrap up totals, but sub-assembly totals is new.
Thank you so much Justin!
I just tried your code and ran into the following error. Any ideas? Does oOcc need to be defined?
Thanks Again!
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 11 of 28
MechMachineMan
I had overlooked adding handling for if it ran into virtual components and derived parts, which I'm guessing you are using, which is what is causing the error?
'Feb 06, 2017
Sub Main()
    Next
End Sub
    oTotalCount = 0
If oParentDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then oThisCount = GetParentNonRefCount(oParentDoc, oSubDoc) oThisPN = oParentDoc.PropertySets("Design Tracking Properties")("Part Number").Value oTotalCount = oTotalCount + oThisCount If oAncestryString = "" Then oAncestryString = oThisPN & "(" & oThisCount & ")" Else oAncestryString = oAncestryString & ", " & oThisPN & "(" & oThisCount & ")" End If
End if Next On Error Resume Next oSubDoc.PropertySets("Inventor User Defined Properties").Item("_AncestryStr").Value = oAncestryString If Err.Number <> 0 Then Call oSubDoc.PropertySets("Inventor User Defined Properties").Add(oAncestryString, "_AncestryStr") End If On Error Resume Next oSubDoc.PropertySets("Inventor User Defined Properties").Item("_TotalCount").Value = oTotalCount If Err.Number <> 0 Then Call oSubDoc.PropertySets("Inventor User Defined Properties").Add(oTotalCount, "_TotalCount") End If End Sub Function GetParentNonRefCount(oParentDoc As Document, oOccDoc As Document) As Integer For Each oOcc In oParentDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(oOccDoc) If oOcc.BOMStructure <> BOMStructureEnum.kReferenceBOMStructure Then oCount = oCount + 1 End If Next GetParentNonRefCount = oCount End Function
Justin K
Message 12 of 28
andrewdroth
Yeah, it's mostly derived parts.
I'll give this a try and get back to you.
Thanks again!
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 13 of 28
MechMachineMan
I guess I should have asked if your derived parts are visible as part of
the item flow, or if it is just purely for modelling purposes that you use
them?
This change just skips adding a tag if the part goes into a derived part.
Justin K
Message 14 of 28
andrewdroth
Yes, most of the parts are derived from a master part.
The code now works with only a couple issues.
One, is it seems to gather the total count from the ancestry count, but that doesn't account for sub-assemblies used more than one. But we can just use the original code I posted for that value.
The other issue is I've utilized a bunch of phantom assemblies for parts then get reused often. Is there anyway to ignore the phantom assemblies, and use their parent assembly part numbers instead? I realize this may be tricky.
Thank you so much for your time.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 15 of 28
MechMachineMan
Shouldn't be too, too terrible to fix it.
I'm assuming this total includes plates used in weldments as well.
Do you use weldments as INSEPARABLE Bom Structure, or have do you switch them to Normal?
Justin K
Message 16 of 28
MechMachineMan
Well it's starting to seem like there is a lot of exception cases and that it doesn't really work easily from top down;
This algorithm would work find, except, working from the Bottom up, if it iterates up and encounters a file that's phantom, it just put in a bunch of information that is incorrect.
Because the control of this all works from TopDown, I actually need to approach the problem that way. Which makes me think it might just be easier to have the Inventor BOMS do all the legwork there for me.
I had spent my lunch working on writing a macro that exports the BOM to an array so that I can process it really fast.. However, it appears that without a sort algorithm, it doesn't ever pull the information sorted by Item number.
Which means when I have time, I'm just going to have to re-write the rule to iterate through the BOM and Push the Parent Row Part Number down to it's sub-components.
Which means I actually need a rule to clear the iProps for a fresh run every time the rule is run, then rewrite the rule to to store the ancestry in the iProps, and then check the iProp before just appending it, so I can modify it with the Parent Occ QTY info.
I'm guessing adding multiple tags for multiple instances of the parent is unacceptable and that you want them all rolled together, eh?
ie;
Assy1
- Sub Assy1
-- Part
-Sub Assy1
--Part
In part, tags should show as: Sub Assy(1), Sub Assy(1) OR Sub Assy(2) OR Sub Assy (2 X 1)?
Justin K
Message 17 of 28
andrewdroth
Yeah, weldments are normal assemblies at the moment.
I suppose 'Sub Assy (2 X 1)' conveys the information the most effectively.
If it's going to be a real hassle don't feel obligated to make it work. We might be able to fumble our way there.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 18 of 28
MechMachineMan
Meh. It's a fun challenge!
Justin K
Message 19 of 28
andrewdroth
Haha, well if you're up for it I'm OK with that.
Thanks Man!
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 20 of 28
MechMachineMan
Ok here is another go.
Hopefully I didn't miss anything else haha
Private oLogStr As String
Sub Main()
    Dim oACD As AssemblyComponentDefinition
    Set oACD = oDoc.ComponentDefinition
    Dim oBOM As BOM
    Set oBOM = oACD.BOM
    Dim oPartsBOM As BOMView
    Dim oStructBOM As BOMView
    With oBOM
        .StructuredViewEnabled = True
        .StructuredViewFirstLevelOnly = False
        .StructuredViewDelimiter = "."
        Set oStructBOM = .BOMViews("Structured")
    End With
    Call PurgeNewiProps(oDoc)
    Call AddAncestryViaStruct(oDoc, oStructBOM)
    Call AddTotalQTY(oDoc)
    MsgBox ("Rule complete!" & vbLf & vbLf & "Custom Properties Used: _AncestryStr & _TotalQTY" & vbLf & vbLf & "Files with issues: " & vbLf & oLogStr)
End Sub
Sub PurgeNewiProps(oDoc)
        If oSubDoc.IsModifiable = True Then
                oSubDoc.PropertySets("Inventor User Defined Properties").Item("_AncestryStr").Value = ""
                oSubDoc.PropertySets("Inventor User Defined Properties").Item("_TotalQTY").Value = ""
        End If
    Next
End Sub
Sub AddAncestryViaStruct(oGADoc As Document, oStructBOM As BOMView)
    Dim oRow As BOMRow
    For Each oRow In oStructBOM.BOMRows
        Call AddAncestryToRow(oRow, oGADoc.PropertySets("Design Tracking Properties")("Part Number").Value, "1")
    Next
End Sub
Sub AddAncestryToChildren(oRow As BOMRow, oParentQTY As String)
    If oRow.ComponentDefinitions.Item(1).Type = ObjectTypeEnum.kVirtualComponentDefinitionObject Then
        Exit Sub
    End If
    Dim oPN As String
    oPN = oRow.ComponentDefinitions.Item(1).Document.PropertySets("Design Tracking Properties")("Part Number").Value
    Dim oPQTY As String
    oPQTY = oRow.TotalQuantity * CInt(oParentQTY)
    Dim oCRow As BOMRow
    For Each oCRow In oRow.ChildRows
        If oCRow.ComponentDefinitions.Item(1).Type <> ObjectTypeEnum.kVirtualComponentDefinitionObject Then
            Call AddAncestryToRow(oCRow, oPN, oPQTY)
        End If
    Next
End Sub
Sub AddAncestryToRow(oCRow As BOMRow, oPN As String, oParentQTY As String)
    Dim oQTY As String
Dim oiQTY As Integer Set oSubDoc = oCRow.ComponentDefinitions(1).Document If oSubDoc.IsModifiable = True Then On Error Resume Next oAncestryString = oSubDoc.PropertySets("Inventor User Defined Properties").Item("_AncestryStr").Value If Err.Number <> 0 Then Call oSubDoc.PropertySets("Inventor User Defined Properties").Add("", "_AncestryStr") oAncestryString = "" End If oQTY = oCRow.TotalQuantity
oiQTY = CINT(oQTY)
MsgBox("Error: A BOM row uses length or a parameter rather than an integer quantity. This rule is not cut out for that." & vblf & vblf & _
"Please revise Base QTY of that part then re-run this rule.") End if
On Error GoTo 0
For j = 1 To oParentQTY oAncestryString = AppendAncestryString(oAncestryString, oPN, oQTY) Next oSubDoc.PropertySets("Inventor User Defined Properties").Item("_AncestryStr").Value = oAncestryString Else oLogStr = oLogStr & vbLf & "NO ANCESTRY ADDED FOR: " & oSubDoc.PropertySets("Design Tracking Properties")("Part Number").Value End If If Not oCRow.ChildRows Is Nothing Then Call AddAncestryToChildren(oCRow, oParentQTY) End If End Sub Function AppendAncestryString(oAncestryString As String, oPN As String, oQTY As String) As String pos = InStr(oAncestryString, oPN) If pos = 0 Then If Len(oAncestryString) = 0 Then oAncestryString = oPN & "(" & oQTY & ")" Else oAncestryString = oAncestryString & ", " & oPN & "(" & oQTY & ")" End If Else openpos = InStr(pos, oAncestryString, "(") closepos = InStr(openpos, oAncestryString, ")") xpos = InStr(openpos, oAncestryString, "x", vbTextCompare) If xpos = 0 Or xpos > closepos Or xpos < openpos Then oAncestryString = Left(oAncestryString, openpos) & "2 X " & Right(oAncestryString, Len(oAncestryString) - openpos) Else oOldQTYx = Trim(Mid(oAncestryString, openpos + 1, xpos - 1 - openpos)) oNewQTYX = CInt(oOldQTYx) + 1 oAncestryString = Left(oAncestryString, openpos) & oNewQTYX & Right(oAncestryString, Len(oAncestryString) - xpos + 2) End If End If AppendAncestryString = oAncestryString End Function Sub AddTotalQTY(oDoc) Dim oSubDoc As Document For Each oSubDoc In oDoc.AllReferencedDocuments If oSubDoc.IsModifiable = True Then oTotalQTY = GetTotalFromAncestry(oSubDoc.PropertySets("Inventor User Defined Properties")("_AncestryStr").Value) On Error Resume Next oSubDoc.PropertySets("Inventor User Defined Properties").Item("_TotalQTY").Value = oTotalQTY If Err.Number <> 0 Then Call oSubDoc.PropertySets("Inventor User Defined Properties").Add(oTotalQTY, "_TotalQTY") End If Else oLogStr = oLogStr & vbLf & "NO QTY ADDED: " & oSubDoc.PropertySets("Design Tracking Properties")("Part Number").Value End If Next End Sub Function GetTotalFromAncestry(oStr As String) As Integer Dim openpos As Integer openpos = 1 Dim multiplier As Integer Dim qty As Integer Dim runningtotal As Integer Do Until oStr = "" openpos = InStr(1, oStr, "(") closepos = InStr(openpos, oStr, ")") xpos = InStr(openpos, oStr, "x", vbTextCompare) If xpos = 0 Or xpos > closepos Or xpos < openpos Then thistotal = Trim(Mid(oStr, openpos + 1, closepos - openpos - 1)) Else multiplier = Trim(Mid(oStr, openpos + 1, xpos - 1 - openpos)) qty = Trim(Mid(oStr, xpos + 1, closepos - 1 - xpos)) thistotal = multiplier * qty End If runningtotal = runningtotal + thistotal oStr = Right(oStr, Len(oStr) - closepos) Loop GetTotalFromAncestry = runningtotal End Function
Justin K
