Inventor Help
Inventor Help
Inventor Help
 I have a series of lofts and extrusions about a dodecahedron. I want to repeat the process on the other sides but I don't know how to do that.Capture.PNG
Does anyone have any ideas?
MechMachineMan
Group all of the features and create an iFeature out of them? Or pattern it on a circular axis at the vertex between 3 faces and repeat?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
pball
I managed to use 1 mirror and 3 circular patterns to get all sides covered. I have a 2017 part attached, if you don't have 2017 I can take a few screen shots of how I did it.
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
