Close invisible drawing
Message 1 of 8
Hi all,
I'm programming an AddIn with VB.NET.
I work with drawing documents and I open they without show the document. The problem is close the drawing! If I active the drawing and call method Drawing.Close() it work fine, if I call the same method with the drawing document invisible it doesn't work and the document stays opened.
Somebody know the problem?
Valerio Pittavino
Replies (7)
Message 2 of 8
Owner2229
Hey, it wouldn't hurt to post your code... Anyway, to be able to control the drawing (and avoid leftover documents) your code should look like this:
Dim oDoc As Document = InventorApplication.Documents.Open("MyDrawingPath", False)
'Or:
Dim oDoc As Document = InventorApplication.ActiveDocument
Try 'Your code working with the drawing Catch End Try oDoc.Save() 'Optional save oDoc.Close()
You can also use "DrawingDocument" instead of "Document" if you know what it will work with is drawing, or add a simple check:
If oDoc.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then Exit Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 3 of 8
thanks for your reply.
The code i'm using is this
''' <summary>
''' Chiude tutti i disegni che sono nascosti
''' </summary>
''' <remarks></remarks>
    Public Sub ChiudiDisegniNascosti(ByVal mDis As List(Of DrawingDocument))
        Dim ElencoAperti As New List(Of DrawingDocument)
        For i As Integer = 1 To g_inventorApplication.Documents.VisibleDocuments.Count
            Dim temp As Document = g_inventorApplication.Documents.VisibleDocuments.Item(i)
            If temp.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
                ElencoAperti.Add(temp)
        Next
        For Each d As DrawingDocument In mDis
            If ElencoAperti.IndexOf(d) = -1 Then
                Try
                    d.Views.Add() 'THIS IS TO SHOW THE DOCUMENT ELSE IT CANNOT BE CLOSE
                    'd.Apri()
                    d.Close(True)
                Catch
                End Try
        Next
    End Sub
I pass a list of drawing to close and the method must close only the invisible documents. To know if the document is visible I check the visibledocuments by inventor.
If I don't show the document by "d.Views.Add()" it will not closed.
I don't want save.
Message 4 of 8
Owner2229
So, this is your workflow, right?
1) Open some drawings as invisible
2) Do some operations with the invisible drawing
3) Close all invisible drawings
Now, this is how it should be:
1) Open ONE drawing as invisible and bind it as variable (e.g. "oDoc" as in my sample)
2) Do some operations with the binded drawing
3) Close the binded drawing
4) Open another drawing
Also, to close all invisible drawings, you could use this:
Public Sub ChiudiDisegniNascosti()
'List through all documents For Each oDoc As Document In g_inventorApplication.Documents
'Skip other than drawings If oDoc.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then Continue For
'Skip visible drawings If oDoc.Visible Then Continue For oDoc.Close(True) Next End Sub
Mike
Message 5 of 8
Thanks but don't work.
Method or property .Visible doesnt exist.
I tryed your code without .visible but the problem is same, if you watch the number of open file don't change
Public Sub ChiudiDisegniNascostiAAAA()
            MsgBox("chiudo " + oDoc.Nome)
            oDoc.Close(True)
        Next
    End Sub
if you try to open any drawing as invisible you can't close it, you must before make it visible.
Smiley Frustrated
Message 6 of 8
Owner2229
Hmm, that's strange. The documents actually don't have the "visible" property and they can't be closed this way (form the Documents enumerator) while they're invisible. I guess that's a bug.
Anyway, you SHOULD stick to the workflow I've suggested you above. This way you'll avoid issues like this.
Mike
Message 7 of 8
I also think which is a bug, I will send a message to autodesk.
I solved yesterday the problem making drawing visible and close just after open.
Thanks for your replies.
Message 8 of 8
I'm writing because I solved the problem.
To close an invisible drawing is need to activete it and after to close it, this is same to before but reading in the API documentation I found the application's property ScreenUpdating, this property allow to not update the screen when you are doing operation then:
lock screen
active the drawing
close the drawing
unlock screen
Thanks for your help
Valerio Pittavino
