ilogic or vb code - derived component
marcin_bargiel
Message 1 of 8
marcin_bargiel
Hi
I need iLogic or VB code for :
1. add  derived component Part2.ipt to Part1.ipt, I actually need only Sketch3
2. then i need to Extrude, type CUT, behavior TO NEXT,  profile, from Sketch3 (circle) to Solid1 in Part1.ipt (i want to just make a hole in Part1.ipt.)
I attached two simple files. In Part1.ipt, there are derived Part2.ipt and Extrusion2 already done manually.
I want to obtain the same result with iLogic.
For clarification why i'm doing this: in fact Part2.ipt always contains complicated shapes (that i want to create only once !), then add Part1.ipt and a lot of instance Part2.ipt to ASSEMBLY.iam.
Part1.ipt it is usually a cylinder or end cap,  shape is easy but there are a lot of holes (i don't want to to this manually by planes, sketech, parameters - this is a long way)
Until now, I have used the master skeleton method, but it is not satisfactory when I have to do, for example, 100 elements in a project.
Vote for REPLACE VARIES !
REPLACE VARIES
Replies (7)
Message 2 of 8
HideoYamada
Hello Marcin,
This code create the features like as that you have created in Part1.
Option Explicit
Sub DerivedTest()
    Dim oDestDoc As PartDocument
    Set oDestDoc = ThisApplication.ActiveDocument
    Dim oDestDef As PartComponentDefinition
    Set oDestDef = oDestDoc.ComponentDefinition
    Dim sourceFullFileName As String
    ' This is dirty hack
    sourceFullFileName = oDestDoc.FullFileName
    Mid(sourceFullFileName, Len(sourceFullFileName) - 4, 1) = "2"
    ' Add Derived Part Feature
    Dim oDerivedPartComps As DerivedPartComponents
    Set oDerivedPartComps = oDestDef.ReferenceComponents.DerivedPartComponents
    Dim oDerivedDef As DerivedPartUniformScaleDef
    Set oDerivedDef = oDerivedPartComps.CreateUniformScaleDef(sourceFullFileName)
    oDerivedDef.ExcludeAll
    oDerivedDef.Sketches.Item("Sketch3").IncludeEntity = True
    Dim oDerivedPartComp As DerivedPartComponent
    Set oDerivedPartComp = oDerivedPartComps.Add(oDerivedDef)
    ' Add Extrude Feature
    Dim oSourceSketch As PlanarSketch
    Set oSourceSketch = oDerivedPartComp.Sketches(1)
    Dim oExtrudeDef As ExtrudeDefinition
    Set oExtrudeDef = oDestDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oSourceSketch.Profiles.AddForSolid, kCutOperation)
    oExtrudeDef.SetToNextExtent kNegativeExtentDirection, oDestDef.SurfaceBodies(1)
    oDestDef.Features.ExtrudeFeatures.Add oExtrudeDef
End Sub
If you heavily use the master skeleton method, my AddIn may help your work.
UCS Derived Component
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Message 3 of 8
marcin_bargiel
Thank's a lot !
A few things i changed :
deleted all "SET" (because of compile error)
I needed to use parenthesis here :
oExtrudeDef.SetToNextExtent(kNegativeExtentDirection, oDestDef.SurfaceBodies(1))
this is better for me  :
'oSourceSketch = oDerivedPartComp.Sketches(1)
 oSourceSketch = oDestDoc.ComponentDefinition.Sketches.Item("Sketch3")
REPLACE VARIES
Message 4 of 8
marcin_bargiel
I can't figure it out how to extrude cut, when i have multibody in Part1.ipt,
1. how to extrude cut only on specific one?
2. how to extrude cut on all of them?
REPLACE VARIES
Message 5 of 8
HideoYamada
Set AffectedBodies before adding an ExtrudeDefinition to a ExtrudeFeatures.
This is VBA code and you may have to modify this if you use in iLogic.
    Dim oCol As ObjectCollection
    Set oCol = ThisApplication.TransientObjects.CreateObjectCollection
    ' Set the 2nd body to be cut.
  oCol.Add oDestDef.SurfaceBodies(2) oExtrudeDef.AffectedBodies = oCol oDestDef.Features.ExtrudeFeatures.Add oExtrudeDef
'Add all of bodies to be cut. Dim oBody As SurfaceBody For Each oBody In oDestDef.SurfaceBodies oCol.Add oBody Next oBody oExtrudeDef.AffectedBodies = oCol oDestDef.Features.ExtrudeFeatures.Add oExtrudeDef
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 6 of 8
marcin_bargiel
Works as expected.
Many thanks !
REPLACE VARIES
Message 7 of 8
RoyWickrama_RWEI
Thanks Hideo Yamada.
Reference Doc: SKIP-DOC0034
Current Doc: "SKIP-DOC0035
Model parameters: Dim_04, Dim_05, ..
User Parameters: Length, Width, Height, ...
I need the rule to be included with the reference doc and the model and user parameters so that just by running, the current document will have all those parameters. Because they are to come on many follow up documents.
I attach the sample files.
I request help. Thanks a lot.
Message 8 of 8
HideoYamada
Hi rwickrama,
I created a sample code and posted it on your thread.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
