these are all:
| A grounded component is selected to move. Would you like to continue?" Response="6" ThisOperation="0"/> |
| Adding this dimension will over-constrain the sketch.
To solve conflicts, highlighted constraints will be removed,
and highlighted dimensions will be changed to Driven dimension.
| An existing part file with the same name but belonging to another family has been found in the Content Center files location. This happens when more than one family uses the same file name(s) for family members. You need to change the file name setting for the current family.
The existing part file will be used to complete the Content Center command." Response="2" ThisOperation="0"/> |
| An existing part file with the same name but belonging to another family has been found in the Content Center files location. This happens when the file name setting was changed so now a family member uses a file name previously assigned to another member.
You need to change the file name setting for the current family. The existing part file will be used to complete the Content Center command." Response="1" ThisOperation="0"/> |
| Any features dependent on this derived feature may be deleted. Do you wish to continue?" Response="1" ThisOperation="0"/> |
| Changes have been made to some assembly components since this assembly was last saved" Response="6" ThisOperation="0"/> |
| Changes have been made to some assembly components since this assembly was last saved which may affect component size and position.
Would you like to update the assembly now?" Response="7" ThisOperation="0"/> |
| Delete component dependent sketches?" Response="6" ThisOperation="0"/> |
| Do you want to calculate the Mass Properties for the Master Level of Detail? If you select 'No' Inventor will calculate the Mass Properties for the currently active Level of Detail. Unresolved components will not be included in the calculation." Response="6" ThisOperation="0"/> |
| Do you want to save the file on close?" Response="7" ThisOperation="1"/> |
| Existing dimensions placed on the geometry may restrict the intended operation. Should these dimensions be relaxed if necessary?" Response="6" ThisOperation="0"/> |
| Marking a Part as a Substitute disables all links to external references. These links can be manually updated but Inventor will not update them automatically. When the Part is no longer marked as a Substitute, all links will be returned to their original state. Continue?" Response="6" ThisOperation="0"/> |
| One or more drawing views are being computed and are currently in raster state. The document(s) may be closed and pending updates will resume when the document is reopened.
Do you wish to continue closing?" Response="7" ThisOperation="1"/> |
| Replace via Resolution" Response="6" ThisOperation="1"/> |
| Save Reminder" Response="1" ThisOperation="0"/> |
| Save changes to the rule?" Response="6" ThisOperation="0"/> |
| Save session edits to component prior to delete?" Response="6" ThisOperation="0"/> |
| Sketch constraint already exists." Response="2" ThisOperation="0"/> |
| Some of the styles selected for update were edited locally in the document. Updating them will discard the edits and replace the style with the definition from the style library. Do you wish to continue?" Response="6" ThisOperation="1"/> |
| Style Conflict" Response="1" ThisOperation="0"/> |
| The column or parameter type does not match the category parameter type. Content Center Search will view the values assigned to this column or parameter as data of the category parameter type. If the values are not relevant to the category parameter type, Search may not correcly locate the member." Response="1" ThisOperation="0"/> |
| The current Level of Detail representation has unsaved changes, which could be lost due to the activation. Continue anyway?" Response="6" ThisOperation="0"/> |
| The current operation requires data from document, but it cannot be found. The document may have been moved, renamed, or deleted. The operation must either be aborted or the file located." Response="2" ThisOperation="0"/> |
| The file can be saved from another window. Save it now?" Response="6" ThisOperation="0"/> |
| The geometry being edited is constrainted to other geometry. Would you like those constraints removed?" Response="6" ThisOperation="0"/> |
| The location of the selected file is not in the search path of the active project file.
To avoid this message, create or activate a project file that contains this folder in the search path before opening. You can also move the file to a folder contained in the current project search path.
Would you like to continue opening the file from the current location?" Response="6" ThisOperation="0"/> |
| The projects could not be found on disk. You may experience performance issues when searching them. Click OK, inventor will not search these projects next time." Response="1" ThisOperation="0"/> |
| The restructure operation may result in lost features due to missing references. Do you want to proceed?" Response="6" ThisOperation="0"/> |
| The selected component geometry has been used. No associativity will be maintained." Response="1" ThisOperation="0"/> |
| The selected location is not in the active project. Do you wish to continue the save?" Response="6" ThisOperation="0"/> |
| The substitute part needs to be updated in order to edit the derived component. Would you like to update now?" Response="6" ThisOperation="0"/> |
| This Part is currently marked as a Substitute. All links to external references are automatically disabled to avoid cyclical dependencies." Response="1" ThisOperation="0"/> |
| This assembly requires an update which when performed may result in either an inability to compute the assembly feature or unexpected compute results." Response="1" ThisOperation="0"/> |
| This operation changes the view style to hidden lines and dependent view styles will become independent.
	Do you want to continue?" Response="6" ThisOperation="0"/> |
You cannot close this window or save the file while in this environment. Would you like to exit the environment and continue?" Response="1" ThisOperation="0"/>A grounded component is selected to move. Would you like to continue?" Response="6" ThisOperation="0"/> Adding this dimension will over-constrain the sketch.
Would you like to continue?" Response="6" ThisOperation="0"/> An existing part file with the same name but belonging to another family has been found in the Content Center files location. This happens when more than one family uses the same file name(s) for family members. You need to change the file name setting for the current family.
The existing part file will be used to complete the Content Center command." Response="2" ThisOperation="0"/> An existing part file with the same name but belonging to another family has been found in the Content Center files location. This happens when the file name setting was changed so now a family member uses a file name previously assigned to another member.
You need to change the file name setting for the current family. The existing part file will be used to complete the Content Center command." Response="1" ThisOperation="0"/> Any features dependent on this derived feature may be deleted. Do you wish to continue?" Response="1" ThisOperation="0"/> Changes have been made to some assembly components since this assembly was last saved" Response="6" ThisOperation="0"/> Changes have been made to some assembly components since this assembly was last saved which may affect component size and position.
Would you like to update the assembly now?" Response="7" ThisOperation="0"/> Delete component dependent sketches?" Response="6" ThisOperation="0"/> Do you want to calculate the Mass Properties for the Master Level of Detail? If you select 'No' Inventor will calculate the Mass Properties for the currently active Level of Detail. Unresolved components will not be included in the calculation." Response="6" ThisOperation="0"/> Do you want to save the file on close?" Response="7" ThisOperation="1"/> Existing dimensions placed on the geometry may restrict the intended operation. Should these dimensions be relaxed if necessary?" Response="6" ThisOperation="0"/> Marking a Part as a Substitute disables all links to external references. These links can be manually updated but Inventor will not update them automatically. When the Part is no longer marked as a Substitute, all links will be returned to their original state. Continue?" Response="6" ThisOperation="0"/> One or more drawing views are being computed and are currently in raster state. The document(s) may be closed and pending updates will resume when the document is reopened.
Do you wish to continue closing?" Response="7" ThisOperation="1"/> Replace via Resolution" Response="6" ThisOperation="1"/> Save Reminder" Response="1" ThisOperation="0"/> Save changes to the rule?" Response="6" ThisOperation="0"/> Save session edits to component prior to delete?" Response="6" ThisOperation="0"/> Sketch constraint already exists." Response="2" ThisOperation="0"/> Some of the styles selected for update were edited locally in the document. Updating them will discard the edits and replace the style with the definition from the style library. Do you wish to continue?" Response="6" ThisOperation="1"/> Style Conflict" Response="1" ThisOperation="0"/> The column or parameter type does not match the category parameter type. Content Center Search will view the values assigned to this column or parameter as data of the category parameter type. If the values are not relevant to the category parameter type, Search may not correcly locate the member." Response="1" ThisOperation="0"/> The current Level of Detail representation has unsaved changes, which could be lost due to the activation. Continue anyway?" Response="6" ThisOperation="0"/> The current operation requires data from document, but it cannot be found. The document may have been moved, renamed, or deleted. The operation must either be aborted or the file located." Response="2" ThisOperation="0"/> The file can be saved from another window. Save it now?" Response="6" ThisOperation="0"/> The geometry being edited is constrainted to other geometry. Would you like those constraints removed?" Response="6" ThisOperation="0"/> The location of the selected file is not in the search path of the active project file.
Would you like to continue opening the file from the current location?" Response="6" ThisOperation="0"/> The projects could not be found on disk. You may experience performance issues when searching them. Click OK, inventor will not search these projects next time." Response="1" ThisOperation="0"/> The restructure operation may result in lost features due to missing references. Do you want to proceed?" Response="6" ThisOperation="0"/> The selected component geometry has been used. No associativity will be maintained." Response="1" ThisOperation="0"/> The selected location is not in the active project. Do you wish to continue the save?" Response="6" ThisOperation="0"/> The substitute part needs to be updated in order to edit the derived component. Would you like to update now?" Response="6" ThisOperation="0"/> This Part is currently marked as a Substitute. All links to external references are automatically disabled to avoid cyclical dependencies." Response="1" ThisOperation="0"/> This assembly requires an update which when performed may result in either an inability to compute the assembly feature or unexpected compute results." Response="1" ThisOperation="0"/> This operation changes the view style to hidden lines and dependent view styles will become independent.
	Do you want to continue?" Response="6" ThisOperation="0"/> You cannot close this window or save the file while in this environment. Would you like to exit the environment and continue?" Response="1" ThisOperation="0"/> |
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
of course:
go to your application options.
export these.
there will be an xml file created.
if you open this you will find them.
That easy....
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
I tried, but the information I got was incomplete, the picture is all I saw when I opened the xml file.
You are running inventor 2019 right.
the same issue was in Inventor 2018, and this was solved with a SP or update.
so they keep having problems with this.
wait till the next update and it will be fixed.
this is a bug of course.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
did you update inventor?
now the version is 2018.3.1
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
The updates should do it for you.
I had the same issue last months.
with the updates it was solved for me at least...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Also read this post related to my and your topic>
Seems that only the edit ones are displayed, I forgot that....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
