Create DXF by Selecting Face while Rule Running
RoyWickrama_RWEI
Advisor Advisor
Message 1 of 9
RoyWickrama_RWEI
The rule works fine if a surface is pre-selected. However, Ideally, I need the user (without pre-selecting) to select the face while the rule is running (i.e. rule execution reminds user to select a face).
I tried a lot without success. I request someone help me. Simplified code is shown below.   Sample file attached here to!
Imports System.Windows.Forms
Dim oFace As Face
Dim formatExport As New ArrayList
oDxf = ".dxf"
oExit = "EXIT"
formatExport.add(oDxf)
formatExport.add(oExit)
oExt = InputListBox("SELECT", formatExport, formatExport(0), Title := "Title", ListName := "List")
If oExt = oExit Then Exit Sub
If oExt = oDxf Then
	i = 0
	While i = 0 'Select one face only
	L_oFace:
	oFace = ThisApplication.CommandManager.Pick(Inventor.SelectionFilterEnum.kPartFaceFilter, "Select face")
		If IsNothing (oFace) Then Goto L_oFace
		i += 1
		planesSelected = planesSelected _
		& vbLf & "FACE " & i & ", SELECTED"
		MessageBox.Show("Message: " & planesSelected, "Title")
	End While	' oFace Is Nothing
nameFolder = ThisDoc.WorkspacePath() & "\"
Clipboard.SetText(nameFolder)
saveAsFileName = ThisDoc.FileName(False) & oExt
oFileName = nameFolder & saveAsFileName
MessageBox.Show("saveAsFileName: " & oFileName, "Title")
Dim oCmdMgr As CommandManager
oCmdMgr = ThisApplication.CommandManager
Call oCmdMgr.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, oFileName)
Call oCmdMgr.ControlDefinitions.Item("GeomToDXFCommand").Execute
Replies (8)
Message 2 of 9
marcin_otręba
I deleted while because it doesn't do nothing and it works... instead of while you can use if  thisdoc.selectset.count = 0 then:
If oExt = oDxf Then
	L_oFace:
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 3 of 9
RoyWickrama_RWEI
Thanks for the posting.
It goes through. But, I do never see any DXF created anywhere.
Although I am not willing to disturb you, could you take a look at. I appreciate your help!
Message 4 of 9
marcin_otręba
delete msgboxes and it will be ok.:
This is whole code...
Dim oFace As Face
L_oFace:
        If oFace Is Nothing Then GoTo L_oFace
oFileName = Left(ThisApplication.ActiveDocument.FullDocumentName, Len(ThisApplication.ActiveDocument.FullDocumentName) - 3) & "dxf"
Set oCmdMgr = ThisApplication.CommandManager
Call oCmdMgr.PostPrivateEvent(kFileNameEvent, oFileName)
Message 5 of 9
RoyWickrama_RWEI
Thanks. Still dxf not creating! But, likely the procedure not ended. If I try to open another document, following pop-up comes on. I guess the selected face is not compatible for creating dxf.
Could we do with a different selection method?
Message 6 of 9
marcin_otręba
Please send me newest file with rule
Message 7 of 9
RoyWickrama_RWEI
Thanks a lot.
I attached the file cw the rule.
Please try to help me.
Message 8 of 9
marcin_otręba
Call ThisApplication.ActiveDocument.SelectSet.clear()
Dim oFace As Face
L_oFace:
If oFace Is Nothing Then Goto L_oFace
Call ThisApplication.ActiveDocument.SelectSet.select(oface)
Call oCmdMgr.ClearPrivateEvents()
Message 9 of 9
RoyWickrama_RWEI
Thanks a lot for the extending help until solution. With the help of your informative codes I could get around my need (see below - it works fine). I also learnt some specific codes. I will expand the code for my other needs as well.
Dim oFace As Face
foderDxfSave = "C:\$WF_DHAMAG\Projects\DHAMAG_SDAI\EWE\"
Clipboard.SetText(foderDxfSave)
oDxf = ".dxf"
oPdf = ".pdf"
oSat = ".sat"
oExit = "EXIT"
formatExport.add(oPdf)
formatExport.add(oSat)
If oExt = oDxf Then
	i = 0
	While i = 0
	'Keep Selecting Faces, Hit Esc to finish
	L_oFace:
'	oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Pick a plane")
		i += 1
	End While
lfnSoueceDocWithoutExt = ThisDoc.FileName(False) 'without extension
ffnSourceDocWithExt = ThisDoc.PathAndFileName(False)
lfnSaveAsWithExt = lfnSoueceDocWithoutExt & oExt
ffnSaveAsWithExt = foderDxfSave & lfnSaveAsWithExt
Call oCmdMgr.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, ffnSaveAsWithExt)
