Message 1 of 15
I create rule which copy all old drawing to new template.
The rule copies everything into the current template except the hole table (i know it's impossible by API) but the origin indicator is copied to the new drawing so I think it isn't possible to create new hole table by API.
I need help in creating a rule that finds a drawing view with a origin indicator, selects this drawing view and creates hole tables for it.
The position of the newly generated table will be set to the upper left corner of the drawing frame.
On screen cast you can see my rule in action and below my code:
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
Dim invCustomPropertySet As PropertySet
invCustomPropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
On Error Resume Next
Dim NAZWAWL As String
NAZWAWL = invCustomPropertySet.Item("NAZWA").Value
'MessageBox.Show(NAZWAWL, "Odczyt nazwy")
If Err.Number <> 0 Then
' Failed to get the property, which means it doesn't exist
' so we'll create it.
Call invCustomPropertySet.Add("", "NAZWA")
Else
'odczyt wielkości arkusza
Dim Size As DrawingSheetSizeEnum
Size = oSheet.Size
'odczyt orientacji arkusza
Orient = OSheet.Orientation
'odczyt nazwy
If iProperties.Value("Summary", "Title")<> "" Then
Nazwa_rys = iProperties.Value("Summary", "Title")
Else Nazwa_rys=NAZWAWL
oDoc.SelectSet.Clear
' Select all drawing views
Dim oView As DrawingView
For Each oView In oDoc.ActiveSheet.DrawingViews
oDoc.SelectSet.Select(oView)
Next
Dim oCopyCmd As ControlDefinition
oCopyCmd = ThisApplication.CommandManager.ControlDefinitions.Item("AppCopyCmd")
oCopyCmd.Execute
Dim oTargetDoc As DrawingDocument
oTargetDoc = ThisApplication.Documents.Open("C:\Standard.idw", True)
oTargetDoc.Activate
Dim oTargetSheet As Sheet
oTargetSheet = oTargetDoc.ActiveSheet
oTargetSheet.Size = Size
oTargetSheet.Orientation = Orient
Dim oPasteCmd As ControlDefinition
oPasteCmd = ThisApplication.CommandManager.ControlDefinitions.Item("AppPasteCmd")
oPasteCmd.Execute
If oTargetSheet.Size = 9997 And oTargetSheet.Orientation = 10243 Then
oTargetDoc.ActiveSheet.Name = "A4 PIONOWO"
ThisApplication.ActiveView.Fit
Else If oTargetSheet.Size = 9997 And oTargetSheet.Orientation = 10242 Then
oTargetDoc.ActiveSheet.Name = "A4 POZIOMO"
Else If oTargetSheet.Size = 9996 And oTargetSheet.Orientation = 10243 Then
oTargetDoc.ActiveSheet.Name = "A3 PIONOWO"
Else If oTargetSheet.Size = 9996 And oTargetSheet.Orientation = 10242 Then
oTargetDoc.ActiveSheet.Name = "A3 POZIOMO"
Else If oTargetSheet.Size = 9995 And oTargetSheet.Orientation = 10243 Then
oTargetDoc.ActiveSheet.Name = "A2 PIONOWO"
Else If oTargetSheet.Size = 9995 And oTargetSheet.Orientation = 10242 Then
oTargetDoc.ActiveSheet.Name = "A2 POZIOMO"
Else If oTargetSheet.Size = 9994 And oTargetSheet.Orientation = 10243 Then
oTargetDoc.ActiveSheet.Name = "A1 PIONOWO"
Else If oTargetSheet.Size = 9994 And oTargetSheet.Orientation = 10242 Then
oTargetDoc.ActiveSheet.Name = "A1 POZIOMO"
Else If oTargetSheet.Size = 9993 And oTargetSheet.Orientation = 10243 Then
oTargetDoc.ActiveSheet.Name = "A0 PIONOWO"
Else If oTargetSheet.Size = 9993 And oTargetSheet.Orientation = 10242 Then
oTargetDoc.ActiveSheet.Name = "A0 POZIOMO"
Dim oNOWYDoc As DrawingDocument: oNOWYDoc = oTargetDoc
Dim WLASCNOWEGO As PropertySet
WLASCNOWEGO = oNOWYDoc.PropertySets.Item("Inventor User Defined Properties")
WLASCNOWEGO.Item("NAZWA").Value = Nazwa_rys
Arkusz=oNOWYDoc.Sheets.Item(1)
'aktualizacja danych
Dim oControlDef as ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("UpdateCopiedModeliPropertiesCmd")
oControlDef.Execute2(True)
'REGUŁA DLA ZAPISU
If Arkusz.DrawingViews.Count <> 0 Then
PNazwa=Arkusz.DrawingViews.Item(1).ReferencedFile.FullFileName
'MessageBox.Show(PNazwa, "Title")
Pozycja=InStrRev(PNazwa,"\", -1)
NazwaModelu=Right(PNazwa,Len(PNazwa)- Pozycja)
scieżkaRysunki = ThisDoc.WorkspacePath()& "\" & "Rysunki"
'MessageBox.Show(scieżkaRysunki, "scieżka")
If (Not System.IO.Directory.Exists(scieżkaRysunki))Then
System.IO.Directory.CreateDirectory(scieżkaRysunki)
NumerCzesci=iProperties.Value(NazwaModelu, "Project", "Part Number")
'MessageBox.Show(NumerCzesci, "Title")
Plik=scieżkaRysunki & "\" & NumerCzesci & ".idw"
'MessageBox.Show(Plik, "PLIK")
oDoc.Close(False)
On Error Resume Next'Goto ZAPISZ'
oNOWYDoc.SaveAs(Plik, False)
'REGUŁA DLA NAZWY RYSUNKU
iProperties.Value("Custom", "NAZWA")= iProperties.Value(NazwaModelu, "Project", "Part Number")
InventorVb.DocumentUpdate()
'If WLASCNOWEGO.Item("NAZWA").Value = ""
'TYTUL = InputBox("PODAJ NAZWĘ ELEMENTU", "NAZWA RYSUNKU", WLASCNOWEGO.Item("NAZWA").Value)
'WLASCNOWEGO.Item("NAZWA").Value= TYTUL
'InventorVb.DocumentUpdate()
'Else
'End If
i = GoExcel.FindRow("BOM.xls", "Arkusz1", "Numer części", "=", iProperties.Value("Project", "Part Number"))
iProperties.Value("Custom", "SZTUKI") = GoExcel.CurrentRowValue("ILOŚĆ")
TYTUL = InputBox("PODAJ NAZWĘ ELEMENTU", "NAZWA RYSUNKU", iProperties.Value("Custom", "NAZWA"))
iProperties.Value("Custom", "NAZWA")= TYTUL
End IfCan you help me with code to create hole table ??
Thanks in advance,
ralfmj
