Hole table add on drawing with existing origin indicator by rule
14 REPLIES 14
Message 1 of 15
ralfmja
1190 Views, 14 Replies
I create rule which copy all old drawing to new template.
The rule copies everything into the current template except the hole table (i know it's impossible by API) but the origin indicator is copied to the new drawing so I think it isn't possible to create new hole table by API.
I need help in creating a rule that finds a drawing view with a origin indicator, selects this drawing view and creates hole tables for it.
The position of the newly generated table will be set to the upper left corner of the drawing frame.
On screen cast you can see my rule in action and below my code:
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
Dim invCustomPropertySet As PropertySet
invCustomPropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
On Error Resume Next
    Dim NAZWAWL As String
    NAZWAWL = invCustomPropertySet.Item("NAZWA").Value
'MessageBox.Show(NAZWAWL, "Odczyt nazwy")
    If Err.Number <> 0 Then
        ' Failed to get the property, which means it doesn't exist
        ' so we'll create it.
        Call invCustomPropertySet.Add("", "NAZWA")
    Else
	End If
'odczyt wielkości arkusza
Dim Size As DrawingSheetSizeEnum
Size = oSheet.Size
'odczyt orientacji arkusza
Orient = OSheet.Orientation
'odczyt nazwy
If iProperties.Value("Summary", "Title")<> "" Then
Nazwa_rys = iProperties.Value("Summary", "Title")
Else Nazwa_rys=NAZWAWL
End If
oDoc.SelectSet.Clear
' Select all drawing views
Dim oView As DrawingView
For Each oView In oDoc.ActiveSheet.DrawingViews
oDoc.SelectSet.Select(oView)
Next
Dim oCopyCmd As ControlDefinition
oCopyCmd = ThisApplication.CommandManager.ControlDefinitions.Item("AppCopyCmd")
oCopyCmd.Execute
Dim oTargetDoc As DrawingDocument
oTargetDoc = ThisApplication.Documents.Open("C:\Standard.idw", True)
oTargetDoc.Activate
Dim oTargetSheet As Sheet
oTargetSheet = oTargetDoc.ActiveSheet
oTargetSheet.Size = Size
oTargetSheet.Orientation = Orient
Dim oPasteCmd As ControlDefinition
oPasteCmd = ThisApplication.CommandManager.ControlDefinitions.Item("AppPasteCmd")
oPasteCmd.Execute
If oTargetSheet.Size = 9997 And oTargetSheet.Orientation = 10243 Then
oTargetDoc.ActiveSheet.Name = "A4 PIONOWO"
ThisApplication.ActiveView.Fit
Else If oTargetSheet.Size = 9997 And oTargetSheet.Orientation = 10242 Then
oTargetDoc.ActiveSheet.Name = "A4 POZIOMO"
Else If oTargetSheet.Size = 9996 And oTargetSheet.Orientation = 10243 Then
oTargetDoc.ActiveSheet.Name = "A3 PIONOWO"
Else If oTargetSheet.Size = 9996 And oTargetSheet.Orientation = 10242 Then
oTargetDoc.ActiveSheet.Name = "A3 POZIOMO"
Else If oTargetSheet.Size = 9995 And oTargetSheet.Orientation = 10243 Then
oTargetDoc.ActiveSheet.Name = "A2 PIONOWO"
Else If oTargetSheet.Size = 9995 And oTargetSheet.Orientation = 10242 Then
oTargetDoc.ActiveSheet.Name = "A2 POZIOMO"
Else If oTargetSheet.Size = 9994 And oTargetSheet.Orientation = 10243 Then
oTargetDoc.ActiveSheet.Name = "A1 PIONOWO"
Else If oTargetSheet.Size = 9994 And oTargetSheet.Orientation = 10242 Then
oTargetDoc.ActiveSheet.Name = "A1 POZIOMO"
Else If oTargetSheet.Size = 9993 And oTargetSheet.Orientation = 10243 Then
oTargetDoc.ActiveSheet.Name = "A0 PIONOWO"
Else If oTargetSheet.Size = 9993 And oTargetSheet.Orientation = 10242 Then
oTargetDoc.ActiveSheet.Name = "A0 POZIOMO"
End If
Dim oNOWYDoc As DrawingDocument:  oNOWYDoc = oTargetDoc
Dim WLASCNOWEGO As PropertySet
WLASCNOWEGO = oNOWYDoc.PropertySets.Item("Inventor User Defined Properties")
WLASCNOWEGO.Item("NAZWA").Value = Nazwa_rys
Arkusz=oNOWYDoc.Sheets.Item(1)
'aktualizacja danych
Dim oControlDef as ControlDefinition  = ThisApplication.CommandManager.ControlDefinitions.​Item("UpdateCopiedModeliPropertiesCmd")
oControlDef.Execute2(True)
'REGUŁA DLA ZAPISU
If Arkusz.DrawingViews.Count <> 0 Then
PNazwa=Arkusz.DrawingViews.Item(1).ReferencedFile.FullFileName
'MessageBox.Show(PNazwa, "Title")
Pozycja=InStrRev(PNazwa,"\", -1)
NazwaModelu=Right(PNazwa,Len(PNazwa)- Pozycja)
scieżkaRysunki = ThisDoc.WorkspacePath()& "\" & "Rysunki"
'MessageBox.Show(scieżkaRysunki, "scieżka")
	If (Not System.IO.Directory.Exists(scieżkaRysunki))Then
	System.IO.Directory.CreateDirectory(scieżkaRysunki)
	End If
NumerCzesci=iProperties.Value(NazwaModelu, "Project", "Part Number")
'MessageBox.Show(NumerCzesci, "Title")
Plik=scieżkaRysunki & "\" & NumerCzesci & ".idw"
'MessageBox.Show(Plik, "PLIK")
oDoc.Close(False)
On Error Resume Next'Goto ZAPISZ'
oNOWYDoc.SaveAs(Plik, False)
'REGUŁA DLA NAZWY RYSUNKU
iProperties.Value("Custom", "NAZWA")= iProperties.Value(NazwaModelu, "Project", "Part Number")
InventorVb.DocumentUpdate()
'If WLASCNOWEGO.Item("NAZWA").Value = ""
'TYTUL = InputBox("PODAJ NAZWĘ ELEMENTU", "NAZWA RYSUNKU", WLASCNOWEGO.Item("NAZWA").Value)
'WLASCNOWEGO.Item("NAZWA").Value= TYTUL
'InventorVb.DocumentUpdate()
'Else
'End If
i = GoExcel.FindRow("BOM.xls", "Arkusz1", "Numer części", "=", iProperties.Value("Project", "Part Number"))
iProperties.Value("Custom", "SZTUKI") = GoExcel.CurrentRowValue("ILOŚĆ")
TYTUL = InputBox("PODAJ NAZWĘ ELEMENTU", "NAZWA RYSUNKU", iProperties.Value("Custom", "NAZWA"))
iProperties.Value("Custom", "NAZWA")= TYTUL
End If
Can you help me with code to create hole table ??
Thanks in advance,
ralfmj
14 REPLIES 14
Message 2 of 15
chandra.shekar.g
in reply to: ralfmja
@ralfmja,
Please provide non confidential file to test the behavior.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 15
ralfmja
in reply to: chandra.shekar.g
File in attachment.
standard.idw - template
Part.ipt - part and part.idw. drawing for part
Thanks in advance,
ralfmj
Message 4 of 15
chandra.shekar.g
@ralfmja,
Hoping that below iLogic code may be helpful.
Dim oSheet As Sheet
    Else
	End If
Size = oSheet.Size
Orient = oSheet.Orientation
'odczyt nazwy
Else
	Nazwa_rys = NAZWAWL
End If
Next
Dim oPt As Point2d
oPt = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.HoleTables.Item(1).Position.X,oSheet.HoleTables.Item(1).Position.Y )
oCopyCmd.Execute
oTargetDoc = ThisApplication.Documents.Open("D:\Chandra\Autodesk Cases\Inventor\Sep-2019\15742647\SAMPLE\Standard.idw", True)
oTargetDoc.Activate
oPasteCmd.Execute
End If
Dim oControlDef As ControlDefinition  = ThisApplication.CommandManager.ControlDefinitions.​Item("UpdateCopiedModeliPropertiesCmd")
'REGUŁA DLA ZAPISU
	End If
Plik= "D:\Chandra\Autodesk Cases\Inventor\Sep-2019\15742647\"&scieżkaRysunki & "\" & NumerCzesci & ".idw"
oDoc.Close(False)
oSheet = oNOWYDoc.ActiveSheet
oSheet.HoleTables.Add(oNOWYDoc.ActiveSheet.DrawingViews.Item(1), oPt)
'Else
'End If
End If
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 15
ralfmja
@chandra.shekar.g  -  thanks but I find one problem !!!
For my better understanding - you add :
Dim oPt As Point2d
For creating X,Y position of Hole Table
and :
for add hole table to Drawing View 1 but in case when hole table is for the third, fourth drawing view this solution does not work.
Could you look at how to identify the view for which the hole table was prepared and copy it ??
In attachment you find example drawing.
Many thanks in advance,
ralfmj
Message 6 of 15
chandra.shekar.g
@ralfmja,
Try below code for any drawing view.
Dim oSheet As Sheet
    Else
	End If
Size = oSheet.Size
'odczyt nazwy
Else
	Nazwa_rys = NAZWAWL
End If
Next
Dim cnt As Integer
cnt = 0
Dim oPt As Point2d
If oSheet.HoleTables.Count >= 1 Then
		cnt = cnt + 1
		If oView Is oSheet.HoleTables.Item(1).ParentView Then
			Exit For
		End If
	Next
	oPt = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.HoleTables.Item(1).Position.X, oSheet.HoleTables.Item(1).Position.Y)
End If
oCopyCmd.Execute
oTargetDoc.Activate
oPasteCmd.Execute
End If
'REGUŁA DLA ZAPISU
	End If
oDoc.Close(False)
If cnt > 0 Then
	oSheet.HoleTables.Add(oNOWYDoc.ActiveSheet.DrawingViews.Item(cnt), oPt)
End If
'Else
'End If
End If
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 15
ralfmja
@chandra.shekar.g  - thank you very much !!
Thanks for your time which you wasted on it.
Work like I wished.
ralfmj
Message 8 of 15
ralfmja
Hi @chandra.shekar.g ,
I still wanted to return to the topic related to this rule.
I would like to copy additional custom iproperities (if they exist). All or - if it's easier -  like on picture below:
Is it possible and possibly how do I put this in my code ??
Thanks in advance,
ralfmj
Message 9 of 15
chandra.shekar.g
@ralfmja,
Do you want to copy from Model document to Drawing document or vice versa?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 10 of 15
ralfmja
I would like to copy the properties from the old drawing to the new one.
Iproperities which you can see on picture it's a "old drawing" properties. You can see it on example file 🙂
Thanks in advance,
ralfmj
Message 11 of 15
chandra.shekar.g
@ralfmja,
Actually, all custom iProperties are copied while creating new drawing with Standard.idw template. Please check the same.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 12 of 15
ralfmja
You are right - I asked the wrong question. 😐
I meant not copying the properties themselves but their values.
I apologize for this - do you understand what I mean now ?
Can you help with that??
Thanks in advance,
Cheers,
ralfmj
Message 13 of 15
chandra.shekar.g
@ralfmja,
It is observed that values of iProperties are also copied to new drawing.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 14 of 15
ralfmja
@chandra.shekar.g
Unfortunately no 😉
Please look on gif and sample part.
Thanks in advance,
ralfmj
Message 15 of 15
ralfmja
Did you find some time to look at this ??
Cheers,
ralfmj
Technology Administrators
