In Inventor 2018, I have created some iLogic parts to easily create RHS, SHS, flat iron bars and so on from simple templates.
I have exported the parameters "height", "width", "thickness" and "length". I then made an expression in the iProperties description to pull the properties in the format
=RHS <L1>x<L2>x<t> - L=<Length> - <Material>
It could then look like this:
RHS 80x40x8 - L=100 mm - Generic
This works perfectly on my machine - however, when I decided to upload the templates to Vault Basic and put it on 3 of our other workstations, the returned values on all 3 looks like this:
RHS 80,x40,x8, - L=100 mm - Generic
...so Inventor adds a comma after each parameter, and I don't understand why.
I have done the following to troubleshoot:
The only 3 places the comma actually shows is in the
- iProperties Description
- iProperties Custom
- BOM
The iLogic rule used is
iLogicForm.Show("Model Data")
and fires upon creating with the template.
I have attached a photo that shows my problem.
There might be something simple as a setting I have overlooked but at the moment I am stuck.
Has anyone had this issue before and know a fix?
Thanks in advance,
I could not find where is, but I suspect it is depending on Windows setting.
For example, your Inventor uses ',' (comma) as a floating point, but ours uses '.' (dot).
This can be changed at Control Panel of Windows.
(I changed it to comma, and then Inventor was affected)
If you simply add Custom iProperty as number from iProperty dialog, does a comma appear at the end of value?
Freeradical
Hideo Yamada
Thanks for your reply - and sorry for my late response.
I forgot to mention that I already took a look there in the "Region" settings, and on at least two of the machines, its the same - it's set to comma. So I ruled that out.
If I manually input numbers, no parameters, the comma is not there. It seems as if the comma is something that is "generated" within the parameters somehow..
Under Parameters->Custom Property Format i have made it as follows:
Property Type = Number
Unit = mm
Precision = 3,123 (3 decimals)
Setting the precision to 0 removes the comma in the automated description - so its seems like it adds the comma, even though no precision is actually specified.
I just think i found a solution:
Under "Custom Property Format" in "Parameters" i set
Property Type = Text
Unit = mm
And i leave Units String, Leading/Trailing Zeroes unchecked.
I also need to go to iProperties -> "Custom" and modify the "Type" to be "Text" aswell, for all of the parameters.
Why it works in one way on one machine, and in another way on the other, I don't know.
And if it has some consequences somewhere I can't tell yet... I will try using it like this for now.
