Get attributes values from Sketched Symbol
meck
Message 1 of 10
meck
Hey All,
Trying to do something I thought would be simple, but I have having some trouble. I need to see what the user has entered for values in a sketched symbol. I thought I could just iterate through the attributes, but I get an error saying "Object doesn't support this property or method" on the line For Each oAttrib In oSketchedSymbol.oAttribSets.
Here is the whole code...
Public Function GetAttributes(SymbolName As String) As Boolean
    'This function returns true when SymbolName is inserted into the drawing
    invApp = GetObject(, "Inventor.Application")
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
    Dim oSketchedSymbol As SketchedSymbol
    Dim AttSet As AttributeSet
    For Each oSketchedSymbol In oSheet.SketchedSymbols
        If oSketchedSymbol.Name = SymbolName Then
            Dim oAttrib As Inventor.Attribute
                MsgBox (oAttrib.Value)
            Next
    Next
End Function
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
Replies (9)
Message 2 of 10
bradeneuropeArthur
The following:
Public Sub f()
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.activesheet
          On Error Resume Next
MsgBox oSketchedSymbol.GetResultText(oSketchedSymbol.Definition.Sketch.TextBoxes.Item(1))
Next
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 10
dean.morrison
You need to access the text boxes of your sketched symbol.
Attributes are just a way to append data to objects.
I have modified your code below.
Dim oSheet As Sheet
Dim oSketchDef As Sketch
Dim oTextBoxes As TextBoxes
Dim iTextBox As TextBox
Set oSketchDef = oSketchedSymbol.Definition.Sketch
Set oTextBoxes = oSketchDef.TextBoxes
For j = 1 To oTextBoxes.Count
Set iTextBox = oTextBoxes.Item(j)
MsgBox iTextBox.Text
Next
Next
End Function
Hope that helps you.
Dean.
Message 4 of 10
bradeneuropeArthur
Hi @dean.morrison
This does not represent the "Filled in" values, as requested.
This will represent the textbox text's!!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 10
dean.morrison
Yeah! haha thanks.
It would appear i added the wrong part of my code..
I really shouldn't reply to these first thing in the morning!
Message 6 of 10
bradeneuropeArthur
The intention is the same anyway, ha ha.
nice evening
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 10
Darin.Green
@bradeneuropeArthur
How do you set the value for the prompted entry?
Given your suggestion
Which get's the value from the prompted entry value. Is there away to set the value?
If this information was helpful, please consider using the Accept Solution
Message 8 of 10
bradeneuropeArthur
oSketchedSymbol.SetPromptResultText(oSketchedSymbol.Definition.Sketch.TextBoxes.Item(1),"YOUR VALUE")
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 10
Darin.Green
Ah... I kept trying SetResultText instead of SetPromptResultText....
You are the man! Thanks!
Message 10 of 10
bradeneuropeArthur
Your thanks are appreciated....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
