File is a new file, not known to vault
Message 1 of 33
I am runnign an Ilogic script every file on save. The problem is that if this file is new, and hase never been checked in into vault before, then the vault window appears and has to be closed. I would like to run the script only if the file has already beed in vault once before. Is there a way to check this from within Ilogic? Thanks!
Replies (32)
Message 21 of 33
Great thanks!
i warched on how to include the api in ilogic in the header but was not able to find anything.. have a nice weekend Braden
Message 22 of 33
bradeneuropeArthur
This will only work with an add in for me.
So this solution will be vb.net based.
You have a nice weekend too.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 23 of 33
FOUND IT!!!!!!
doc.FileSaveCounter
is the version number of vault also
Message 24 of 33
bradeneuropeArthur
This only checks the qty of saves. Nothing about the vault status or in or not in vault!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 25 of 33
bradeneuropeArthur
Do I need to take a look at the Vault API?
Or is this with this really the solution.
Please let me know.
Otherwise I will not put effort in it.
Thanks.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 26 of 33
If you have the time i would appreciate it.. As you mentioned its not the solution.. 😞
Message 27 of 33
bradeneuropeArthur
Of course.
Please provide me your code you need to run and I implement it in the add in derectly.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 28 of 33
Thanks, i can send you the code on monday!
Message 29 of 33
as requested here is my entire code.. this is executed on save.
would you be so kind to share the project/source code afterwards so if there are changes needed i can make them myself?
Thank you!
Best regards
SyntaxEditor Code Snippet
Sub Main()
Dim IPJ as String
Dim IPJ_Name As String
Dim IPJ_Path As String
Dim FNamePos As Long
'set a reference to the FileLocations object.
IPJ = ThisApplication.FileLocations.FileLocationsFile
If IPJ = "C:\VLT_Wrk\Konstruktion.ipj" Then
 Dim odoc As Document = ThisDoc.Document
Dim eDocumentType As DocumentTypeEnum = odoc.DocumentType
     Select Case eDocumentType
            Case DocumentTypeEnum.kAssemblyDocumentObject
                Vaultpropwriteback(odoc)
		Propcheckdes(odoc, 1)
             Case DocumentTypeEnum.kDrawingDocumentObject
            Case DocumentTypeEnum.kPartDocumentObject
                Propcheckdes(odoc, 2)
      End Select
End Sub
Sub Vaultpropwriteback(odoc As Inventor.Document)
	'' EXECUTE THIS LINE ONLY IF THE FILE EXISTS IN VAULT!
     ThisApplication.CommandManager.ControlDefinitions.Item("VaultPropertyWriteBack").Execute
End Sub
Sub Propcheckdes(oDoc As Inventor.Document, filetype As Integer)
Dim counter As Integer = 0
Dim Desc as String
Dim opened As Boolean = False
Dim alreadyopen As Boolean = False
Desc = iProperties.Value(“Project”, “Description”)
Dim odoc2 As Inventor.PartDocument
Dim odoc3 As Inventor.AssemblyDocument
''see if file is already open
	For Each d As Document In ThisApplication.Documents.VisibleDocuments
		If d.FullFileName = oDoc.FullFileName Then
			alreadyopen = True
	Next
	''restore active window
	Dim odocactive As Inventor.Document
	odocactive = ThisApplication.ActiveDocument
	If String.IsNullOrWhiteSpace(Desc) = True Then
		If filetype = 1 Then
			odoc3 = ThisApplication.Documents.Open(oDoc.FullFileName, True)
		Else
			odoc2 = ThisApplication.Documents.Open(oDoc.FullFileName, True)
		opened = True
	Do Until String.IsNullOrWhiteSpace(Desc) = False Or counter > 0
		iLogicForm.ShowGlobal("Pflichtfelder",FormMode.Modal)
		counter = counter + 1
	Loop
	If opened And Not alreadyopen Then
			odoc3.Close(True)
		Else
			odoc2.Close(True)
	odocactive.Activate
End Sub
Message 30 of 33
marcin_otręba
Try this:
If ThisApplication.CommandManager.ControlDefinitions.Item("VaultDataCardtop").Enabled = True And
   ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckouttop").Enabled = True Then
      Debug.Print "in vault(not checked out) check out possible"
   ThisApplication.CommandManager.ControlDefinitions.Item("VaultUndoCheckouttop").Enabled = True Then
       Debug.Print "in vault checked out"
   ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckouttop").Enabled = False And
   ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckintop").Enabled = False Then
           Debug.Print "in vault locked (not possible to check out)"
If ThisApplication.CommandManager.ControlDefinitions.Item("VaultDataCardtop").Enabled = False Then
          Debug.Print "not in vault"
End If,
i used it this way before switching to vb.net
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 31 of 33
may i kiss you??? 😄
works like a charm! thank you very much!
Message 32 of 33
marcin_otręba
you're welcome mate
Message 33 of 33
bradeneuropeArthur
@marcin_otręba
Without any complexity.
My compliments.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
