Hello
I have a problem with activation autodesk Autodesk 3ds Max 2012 64-bit
the problem is that:
When I clicked on "Activate" and next "Continue" the next screen was "Processing Error"
Your online activation request has returned an error (400) which is not allowing your request to be processed using our automated systems. |
Click the "Use another method" link below to complete the necessary forms and submit your request to the local Autodesk Business Center for your area. A Customer Service Representative will respond within the next 2 business days.
I have a student license
Solved by jessica.t. Go to Solution.
Hello I also have (error 400) problem. I have student license. Could you help me?
Please send me a PM (click on t_gaisf profile name and then Send this User a Private Message) with your Serial Number, the request code and confirm the registered name or contact our licence assistance team for direct support.
Dear Support!
Could someone help me too? I got the same error while trying to activate my student licences (Maya and 3ds Max 2014). I was so glad to find the student licences but I can't activate my products. I tried Register Once aswell but it gave me some other error message. 😞
Hello @Anonymous and @Anonymous!
Can you both please contact our License Assistance Team (Activation and Registration -> Activating a Product -> Activation Codes and Request Codes -> I Still Need Help) for direct activation support if you're still in need?
Hello philip.s
I wrote a Support Request last weekend and got no reply. Is this normal and should i wait a little bit longer ?
@Anonymous I was unable to find a case submitted under your email address. As such would you mind resubmitting to our License Assistance team?
@Anonymous At the moment, activation error 400s' require a manually generated activation code in order to resolve. Can you please also contact our License Assistance team for direct support.
To find self-service solutions or reach us via Chat for Activation and Licensing Help:
Visit http://knowledge.autodesk.com/contactus
Select “Activation & Registration” or “License Management”
Select appropriate subtopics from the pull-down menus.
Select “I Still Need Help” if you need personal assistance.
Hi Autodesk,
I have the same error again. With CAD and Revit I needed a new activation code. Now I need Autodesk Robot for my education, and I got error 400 again, again. Can one of your supporters help me, so I can send my informations and get a new, working activation code!
Thanks a lot!
/Mikkel Færgemand
Aalborg University
Hi @Anonymous,
For direct activation and licensing assistance, please contact our License Assistance team by clicking on this link and then following the prompts:
You will be able to contact the License Assistance Team either via Chat or e-mail.
Thank you
If the online activation does not work please send me a PM (click on t_gaisf profile name and then Send this User a Private Message) with your Serial Number, the request code and confirm the registered company name or contact our licence assistance team for direct support.
Hi toha75,
Please, send me your serial number and request code via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message) and I'll look into this for you.
For direct activation and licensing assistance, you can also contact our License Assistance team by clicking on this link and then following the prompts:
Thank you
Same. Got error 400, while trying to activate Autocad 2013, and 2014. none works.
Can anyone help, it's urgent.
Hi Fatima,
Please send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with your Serial Number and Request Code.
Hello, I have a problem to activate 3ds max 2013 . Please help me quiekly to activate the 3ds max 2013. Serial Number: XXX-XXXXXXXX Product Key: 495E1 Request code Thank you.
Hi @Anonymous welcome to the community!
I've removed the serial number from your post. For future reference, please do not post your product serial number in publlic sites or forums such as this one.
Please, send me your request code via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message) and I'll look into this for you.
Thanks!
Edited by
Discussion_Admin
Please be aware that this is a public forum posting serial numbers or personal information is not advised
Discussion_Admin
