Installation & Licensing
Message 1 of 14
AdeEFC
533 Views, 13 Replies
New Server
Hi We have recently got a new server installed.  I have installed the latest licence server manager on it and downloaded a new licence file.
I am having trouble getting the client machines to connect to the new server though.
How do I tell the  Autodesk software on each machine to look for the new licence rather than the old one?
also I have tried installing Autodesk programs on my computer and they just wont find the licence.
there is no problem with the network connecting to the server through windows explorer and I am using the new server to run other software via a Licence manager.  it just seems to be the Autodesk software that wont connect
13 REPLIES 13
Message 2 of 14
Mark.Lancaster
in reply to: AdeEFC
@AdeEFC
All existing machines must be redirected to the new license server by this system variable
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-specify-license-s...
Mark Lancaster
Message 3 of 14
robBouch
in reply to: Mark.Lancaster
Hello @AdeEFC
Welcome to the community!
You should use the ADSKFLEX_LICENSE_FILE environment variable on the client machines as suggested by @Mark.Lancaster.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 4 of 14
robBouch
in reply to: AdeEFC
Hello @AdeEFC
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 5 of 14
AdeEFC
in reply to: robBouch
Hi it did work for a day but then I started getting this error Capture.PNGmessage on my License server, I have tried turning the fire wall off and seeing this that does anything.  I have tried downloading a new licence file and neither of these things worked.
Message 6 of 14
Mark.Lancaster
in reply to: AdeEFC
@AdeEFC
Go to Windows services on your server and locate the name of the services that you created.   Stop the services and go back to the license manager and start the services.  Does it work now?
Mark Lancaster
Message 7 of 14
AdeEFC
Capture.PNGThanks for the reply mark.  when I try to restart the server is gives me the following message below
Message 8 of 14
Mark.Lancaster
in reply to: AdeEFC
@AdeEFC
Provide the log file here..  Go to the config service tab and log location will be defined there.
Mark Lancaster
Message 9 of 14
AdeEFC
Mark
Please find attached Log File
Message 10 of 14
Mark.Lancaster
in reply to: AdeEFC
@AdeEFC
There's nothing attached?  Did you reply via email?  If you did..  Attachments are automatically removed for security reasons.  Come back to the posting and attach there.
Mark Lancaster
Message 11 of 14
AdeEFC
oh Not sure why it removed the attachment will try again
Message 12 of 14
AdeEFC
in reply to: AdeEFC
Morning mark
I have just had a look at the debug file and it does not seem to have anything in it
Message 13 of 14
Mark.Lancaster
in reply to: AdeEFC
@AdeEFC
A debug log file is never empty..   It always has something in it..
Mark Lancaster
Message 14 of 14
AdeEFC
Managed to get it working thanks for your help Mark
Administrator Productivity
