Installation asking for DVD 1
Just downloaded the files (Inventor Proffesional 2017) from Autodesk and while installing it asks for DVD 1, any suggestion?
Thanks a lot!
TravisNave
Correct. Do not attempt to install from USB stick or from any other media except locally.
Also, Inventor has more than one download file. Make sure that you have downloaded all parts.
If you are having problems downloading your 2017 software from your Autodesk Accounts page or from the Trial version, then please see this list of downloads provided here:
http://forums.autodesk.com/t5/installation-licensing/community-downloads/td-p/6314550
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
