Installation & Licensing
How to change the install pathway after a previous install?
4 REPLIES 4
527 Views, 4 Replies
I have been using AutoCAD for a while now and recently decided to upgrade my computer a little by getting a SSDrive.
To be fair, I thought it would be fairly simple to deinstall the software and reinstall on the new drive, but sadly no.
My current problem is the following:
- I have removed everything which I can deinstall through the controll panel.
- I have removed all files from Program Files
- I have removed all files from Program Files(86)
- I have removed all files from ProgramData
- I have removed all files from C:\User
However the installation tool keeps giving me the following warning:
An AutoCAD 2018-based product has been previously installed. Please note that all sebsequent AutoCAD 2018 products will be installed to: C:\Program Files\Autodesk\AutoCAD 2018\
My question:
Is there any way I can remove this fixed pathway and change it to the new drive?
Thank you in advance,
Efraim Steurbaut
My question:
Efraim Steurbaut
4 REPLIES 4
Alfred.NESWADBA
Alfred.NESWADBA
from what I see you missed the registry as well as licensing content.
Please find here the steps for a clean uninstall >>>click<<<
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
- alfred -
Alfred NESWADBA
leowarren34
leowarren34
Completely uninstall ACAD using MSFixit and ADSK removal tools which should remove all links, worst comes you could clone your drive....
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Leo Warren
in reply to: Alfred.NESWADBA
Thank you. That managed to get it going.
However, now it tends to give me an error along the lines of:
Couldn't install AutoCAD 2018. To install, you must have AutoCAD 2018 installed.
Any ideas on how to fix that?
Alfred.NESWADBA
Alfred.NESWADBA
That sounds like you try to install a service pack for AutoCAD 2018, not the product itself.
- alfred -
Alfred NESWADBA
- alfred -
Alfred NESWADBA
Administrator Productivity
