Hi - I work on a laptop from various locations and so I borrow an AutoCAD license from our office server for a maximum of six months at a time. It's now expired and I can't go back to the office to re-borrow it.
My boss has requested a Home Use License which has been approved by AutoDesk. He's sent me the serial number and product key. When I try to input this it says 'Not-Valid'.
The email from Autodesk says:
To use a Home Use serial number, install your software and select "Standalone" when prompted.
However when I install / reinstall AutoCAD there is no option for this.
Any ideas?
Solved by mdavis22569. Go to Solution.
What KEY ( NOT SERIAL NUMBER) are you using ... 6 characters ....
What Software is it for?
Hello @Anonymous,
Thanks for posting.
Please provide a screenshot of the "Let's Get Started" screen, depending on the version the screen display is different, also the latest versions require a licensing update. To better assist you please provide this information.
For 2020 or later versions:
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hi Natasha. thanks for your help though still not working I am afraid.
I have installed all the updates as you suggested and restarted my machine.
I am using AutoCAD 2020 and can confirm the home use license is for this version.
Screenshots are attached. I get an error when trying it tries to activate the codes.
this is an issue that's been going on for about a week - two weeks now.
Need to put a support ticket in and get help from the licensing department
Thank you Michael
Do you or anyone out there know how to do this?
I'm only on a forum as it was the only way I could see of asking for help.
HI @Anonymous
Couple of ways
https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options
