Autodesk Software Suddenly Not Activated
TravisNave
Mentor Mentor
Message 1 of 42
TravisNave
Problem:  You launched your Term Autodesk software today and got a screen to activate your software, but it does not work.  You have no way to open and use your software.
Reason:  Autodesk is experiencing technical problems today as they move to migrate to the 2019 versions of your software.  Currently many of the products that are set to migrate, including AutoCAD, AutoCAD LT, 3DS MAX, and others are experiencing this problem.  Your Autodesk Account management page may show your product but will show no available assignments for those products.  Seemingly, your software has disappeared.
Work-Around:  I have found a work-around that will let you temporarily launch your software and continue to work until this problem is resolved.
Step 1:  Traverse to the following folder location on your computer:
C:\ProgramData\Autodesk\CLM\LGS\<ProductKey_ProductVersion>\
You may have multiple product folders.  Your correct product will start with your product key and end with the release year of the problematic software.  Product keys can be found here.
Step 2:  Rename the LGS.DATA file to something else (i.e. LGS.DATA.BAK)
Step 3:  Launch your Autodesk software and choose to Start a Trial.
Step 4:  Login with your Autodesk account and use your trial for 30 days if necessary.  Note:  If you have already used your product as a trial previously before activation, then this process will not work for you.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Replies (41)
Message 2 of 42
TravisNave
This is only a temporary issue while the Autodesk system is upgraded to 2019.  Once the products are working again, you can follow the steps again to put your software back on Term or activate as appropriate.
Autodesk Forums:
Message 3 of 42
mdavis22569
SMH ....
A lot of frustrated people out there ....
going to just leave it at that ...
Mike Davis
Message 4 of 42
TravisNave
Oh yeah, it hit us first thing this morning so I had to kick-start my brain into "work-around" mode to get my people up and running as well as all the customers who are going to flood support.  This at least allows them to be productive while Autodesk fixes the backend issue.  If you have network licenses, you can also use this method to point to your local NLM, which is what we did.  Just FYI.
Autodesk Forums:
Message 5 of 42
RobH2
Thanks. This works. I just have a deadline and now I won't miss it.
Rob Holmes
3ds Max (2025-2027), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Message 6 of 42
chriscowgill7373
so what do I do if I already used up my trial?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 7 of 42
mdavis22569
@TravisNave
not working for me ....
getting this now over and over ....
Not happy ....
Mike Davis
Message 8 of 42
panky3d
Same here, makes no difference, I keep getting the "Contact your administrator..." window regardless.
I have now lost an entire work day, still waiting for an update from customer support.
Message 9 of 42
TravisNave
Try logging out first and then try again.
Autodesk Forums:
Message 10 of 42
varun_nct
Thanks for sharing vauable information.
But how AUTODESK  so inresponsive without any intimations or notifications or alerts they planned such huge task.
Alright since yesterday from 6PM it started working well.
Shankar Chavan.
Message 11 of 42
finnurp
Unfortunately the situation has lasted for nearly 24 hours and no work done.
Can we send the bill to Autodesk?
Finnur P.
AutoCAD
PD&M Collection
Message 12 of 42
Is there any news related to this problem? I see some users report that it is fixed but we are still having problems with Navisworks Simulate 2018.
Message 13 of 42
mdavis22569
Nope ..I'm seeing a lot of tickets for this today too (since 3am EST)
I still haven't gotten mine resolved yet either.
Mike Davis
Message 14 of 42
mdavis22569
2019 a.pngN
Not a good way to start off the 2019 releases ...
Mike Davis
Message 15 of 42
AntiqueAlan
I am a developer of add on products in the AutoDesk Developer Network and also have this problem.
I have the following programs installed -
2013 basic - works
2014 Arch - works
2018 basic - does NOT work
2018 Arch - works
2019 basic - does NOT work
So I can get some work done, but it is truly frustrating.
Note -
There is the a message in rust color at the top of the forum "Some customers may experience delays...."
You can also check manage.autodesk.com to see a similar message.
I think of delays in terms of hours, not days.
PLEASE FIX THIS PROBLEMS.
Message 16 of 42
mdavis22569
@AntiqueAlan
You're experiencing about the same for me
I put 2019 into trial mode, can't for the 2018, those are all used up
Mike Davis
Message 17 of 42
chriscowgill7373
my temp solution because I had used my trial up with licensing issues when I first installed, was to break my license by disconnecting my test rig from the internet, it will allow me to use my software for 7 days before the license must be repaired.  This is a pain, because I cant get files to a computer that has no connection to the outside world.
Message 18 of 42
hermitch
What if you just deny access to Autodesk- respectively License-related sites/IP-adresses through your firewall/router...
instead of completely cutting your workstation from network/internet?
[EDIT] Layout [/EDIT]
Message 19 of 42
chriscowgill7373
Not really 100% sure how I would do that. I'm working on a VM and sharing my connection through another computer.
Message 20 of 42
pendean
Community Legend
Community Legend
Looks like all subscription (not maintenance or legacy) software is affected this way: logging in and out as well as workarounds posted are not working.
Now this is a good reason to abandon Autodesk subscription model.
