ATC AutoCAD 2018 Licence no more activated.
BL-GL
BL-GL
Since last monday, when we launched our AutoCAD 2018 product, after the step "Verifying Licence" in the splash screen, we obtain a dialog box meaning that we are not authorized to use this licence and that we have to reactivate this licence with an account login.
The pb is the same with all our machines (more than 15).
Does anybody knows what happens ans we can do to fix this problem ?
All of our machines do not work and we had to cancel all our trainings.
That is a important lost of time and money.
Mark.Lancaster
@BL-GL
Autodesk is experiencing technical issues regarding this.  If you can, disconnect from your network/internet and see if you can launch the application.
Mark Lancaster
TravisNave
I have created a work-around for this today and I will be publishing a KB article about it shortly.  Stand by.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
TravisNave
